Question about Dell 3100cn Laser Printer
Dell 3100cn Its about 2 years old but is lightly used, the only cartridge I have replaced is the black one. since then it has started to but a vertical line of black blobs no more than 1mm wide and about 10 per page. have reinstalled black cartridge and used the cleaning stick to try and resolve the problem, but with no luck. I dont thin its the drum as it is desgned for much greater use tah I give it (about 20 pages a day), any suggestions ianjholder@btinternet.com Ian J holder
  • jetman05 May 06, 2008
    tried that, someone also mentioned recalibrating the printer and cleaing the nozzles. the instruction manual does not mention how to do this
    Ian
  • jetman05 May 07, 2008
    Fixed--- it was the drum and Dell sent me a new one as the last one went only two months ago
    Cheers for the help
    Ian
  • 3,037 Answers
Vertical lines almost always originate in the toner cartridge. Since you just replaced it, this would be the obvious place to start. Replace the cartridge, hopefully you can return it and get a new one free if you just purchased it.
Also try wiping off all metal contacts first and gently shaking the cartridge a little.
Let me know if you have any further questions.
thanks
Posted on May 01, 2008
  • Benjamin Patri
    Benjamin Patri May 06, 2008
    the printer should automatically calibrate itself if it needs to.
    Check out these two links below
    Click HERE
    Click HERE
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    sounds good, please let me know if you have any further problems, thank you
    Genius:
  • 3,587 Answers
Ian,
did you do a nozzle clean and re calibrate, by chance? That's usual after the time cycle(in fact, should be done once a month).
Pat the Printer Man
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Jan 27, 2010 | Dell Office Equipment & Supplies
I have a dell 3100cn that will not print as it continually states "replace cartridge". After replace cartridge plus many time reboot, it is not working. Any idea and suggestion?
There could be a problem with either the software or the driver of the printer.
1)Try reinstalling the printer to see if that works
2)Make sure the driver is up to date.
You can check online for drivers by accessing the device manager.
Start -> Control Panel -> System -> Hardware (Tab) -> Device Manager
If any icons are yellow and have an exclamation mark try right clicking it and clicking update driver. If you read the next steps they will guide you through.
3) If after these steps it is still not working correctly, you can phone dell at their toll free number, have your printers serial number ready so that they can help you even faster. Sometimes the call can take awhile but just be patient.
Oct 26, 2009 | Dell 3100cn Laser Printer
Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
Try the cleaning rod. visit: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
Cheers
Oct 22, 2009 | Dell 3100cn Laser Printer
Hi, My Dell 3100CN printer is displaying "Change Black Toner." I have replaced the toner cartridge. The printer begins to calibrate for a very long time. When it finally finished calibrating, it return to...
There is a chip in each toner cartridge which tells the main machine something about how full it is. It may be that it tells it how full it is, or it may be that it tells it how many pages it has done. It sounds as if the new black cartridge has a duff chip, and is telling the main machine that it is empty. To test this, you can overide the message. 1. press on the menu button;
2. select configure;
3. select maintenance;
4. select non-dell toner;
5. set the value to on.
If that does't work, get back to me.
Tony Ludlow
Feb 22, 2009 | Dell 3100cn Laser Printer
LDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
Nov 14, 2008 | Dell 3100cn Laser Printer
Dell 3100cn printer trouble
this sounds like you might have 2 problems on you fuser is not getting hot enough to fully fuse the toner to the paper and two your black toner cartridge has been comprimised and needs to be replaced
Oct 16, 2008 | Dell 3100cn Laser Printer
Laser printer problem
For starters aftermarket cartridges are just not like the new ones from Dell. I quit using aftermarket ones long ago to save these headaches, with Dell you can get on Dell Chat and they will gladly help with issues like this. Try that with "Bob's Printer Cartridge and Music Rental" you won't get anywhere.
Mar 13, 2008 | Dell 3100cn Laser Printer
Streaks on left side
REPLACE DRUM CARTRIDGE THE CLEANER BLADE IS BAD
Jan 20, 2008 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
116 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
