Question about Necchi 3101 Mechanical Sewing Machine
Necchi 534FB Threaded machine and bobbin and machine jams. Can here motor but needle does not move. When trying to turn wheel on side of machine, it jams. Can you help?
  • 2 more comments
  • Anonymous May 06, 2008
    i have the same problem. my machine jams up and its driving me crazy!!!! drewlove80@yahoo.com thanks
  • Anonymous Jun 28, 2008
    NECCHI 534FB Sewing Machine
    Just unpacked my sewing machine from cross country move. It's been a box for over a year. Used air can spray to clean off what little dust was on it and plugged it in. I can hear the motor operating but the needle does not move. I removed top and wheel plates to see if I could figure out what was wrong. I was able to get the hand wheel to operate the bobbin threader but I still could not manage to get the metal arm that drive the needle to move and when I try using the hand wheel to move the needle up and down manually it is very, very difficult. Any advice would be greatly appreciated.
    Diane O
    abugnut
  • Anonymous Mar 29, 2014
    Could you tell me what year this model was made?
    Problem Solver:
  • 8 Answers
I solved this problem for a friend,!. the needle was in the wrong way and
2 the bobbin case was not properly seated be sure you hear the 'click 'when
reinserting the bobbin case...hope this is helpful Velz
Posted on Jul 18, 2009
My mom lost her instructional manual, where can I get one?
Posted on Sep 19, 2008
Top thread too tight?
make sure tat the thread is between the tension plates and not behind and jamming on the bolt
proper tension is a slight resistance when you pull the thread to thread the needle
Oct 20, 2016 | Necchi Sewing Machines
I need a manual on a necchi 535fa
Try this web site:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
Jun 11, 2015 | Necchi Sewing Machines
Stuck bobbin
Please put on the bobbin correct size. And check the tension . Then use new threads.
Dec 19, 2013 | Necchi Sewing Machines
I have a metal spernova child's sewing machine. I have threaded it, but it keeps jamming up. It doesn't create the chain stitch on the fabric. What am I doing wrong??
put in a new needle
clean under needle plate for loose threads or lint
clean bobbin area for same
check the top tension to make sure it correct for the fabric
make sure its threaded correctly top & bobbin
make sure the top thread does not come off the thread take up lever
Aug 03, 2011 | Necchi Sewing Machines
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Sep 26, 2010 | Necchi Sewing Machines
The needle jams when i start sewing
Could be threaded wrong - check manual for proper threading
Needle could be bent - check and replace if needed
Needle plate could be damaged - see if any burrs are on it if so take to service dealer and have removed
Bobbin could be wound wrong - check manual
Bobbin could be bent - if so replace.
Jul 09, 2010 | Necchi Sewing Machines
I've got a Necchi 535FA with a bobbin thread that doesn't hook.
Sounds to me like you may have put the needle in backwards. The flat side should be to the back.
Rick
Aug 24, 2009 | Necchi Sewing Machines
Bobbin/raceway and timing problem; Necchi 3577
ok.....without the bobbin case in and a fresh needle in, turn the machine to the side and turn the crank wheel counter clockwise, the hook of the machine should bypass the cusp of the needle, thats the part of needle that is by the eye and curves in alittle, if it is not the timing is off, try to adjust this by adjusting the needle bar, this is not a easy easy repair but takes patients, im assuming that, thats where it was thrown off timing
Jan 21, 2008 | Necchi 3537 Mechanical Sewing Machine
Necchi 3101 Mechanical Sewing Machine Logo
1,031 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
