Question about Dishwashers
Miele G 841 dishwasher -power appears and disappears mysteriously (green light off). Closing and reclosing the door doesn't help. Have checked the water supply (both entrance and exit). It will just come back on by its own accord.
  • gyges03 May 01, 2008
    No, it does not start. I have checked the plug and that seems ok.
    Genius:
  • 3,587 Answers
Well..sounds to me like the power is uncertain..check the plug and socket in wall, and maybe spread the tines a bit to get a better connection. Failing that, move it to another plug, and see if same thing happens(ok for temporary testing, but not for long term, if you use a three prong extension cord)
Posted on May 01, 2008
  • Patrick Michaels
    Patrick Michaels May 01, 2008
    he..he..you might want to wait on doing the Fixya until you get some real assistance, no? Try that approach I mentioned, to isolate the power input from the machine operation , please..
    Guru:
  • 1,894 Answers
Your machine does not start >? right?
  • dewan nafees ahmed May 01, 2008
    if so try a different power supply.
    if not then make a multimeter ready.
    and then proceed at UR WON RISK
    check if the motor is receiving proper supply power at its brushes.
    even if its receiving then note if the motor tries to rotate when power is given..
    if so there s a fault with motor windings.
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
Miele G863 SCVi All lights blink at the end and it doesn't dry
Check the web for,
2011-11-25_043923_g600__800_miele_service_manual.pdf
I found that PDF while working on fixing my Miele dishwasher and found it more helpful then most advice on the web.
Dec 30, 2012 | Miele Dishwashers
Do ALL series 2xx2 miele dishwashers have comfort door closing aids?
Comfort closing systems were introduced in the last 5yrs, I am not sure about the G2XXX series - but certainly find these on G5XXX and later models.
Most of the G2XXX I have worked on did not have these luxuries...
Jun 18, 2011 | Miele Dishwashers
Our dishwasher is blinking CL - i think this means 'Close'... Even when the door is properly closed, it blinks CL and won't start!! Help!
Hi
Error CL appears when the dishwasher control detects door switch is open or door is open. You'll have to open the door and check the continuity of the door switch. If the door seems to be closed then it is the control has detected an issue with the door latch. Check the door latch & seals to make sure door is closing fine. Unplug the dishwasher from power outlet and wait for 10-15 minutes. Restart the dishwasher and check if the error is still there. If error still appears then you'll need to repalce the door switch/door latch. Hope this helps... Please post back for further assistance.
Daniel
Mar 24, 2011 | Frigidaire Professional Series 24 in....
Miele G892 dishwasher stopped working. No lights at all. There is power from the outlet to the block behind the kick plate. According to manufacturer, there should be lights even with the door open so this...
This seems to be a failure of the main program controller unit.It needs to be confirmed that the unit received power, if so the controller is faulty.
Check if there is any fuse , check if there is line break to the unit.
Mar 12, 2011 | Miele Touchtronic G892 Built-in Dishwasher
On the display is a flashing CL, according to the manual the latch is not closed. Tried several times to close the door and push the normal wash button. Nothing happens, only the CL light is on. Tried...
Hi
Daniel
Nov 26, 2010 | Frigidaire PLD2855RFC Dishwasher
Miele g 851 sc i have a leak under the unit (below the right door hinge) when i run the machine
hi,
make sure you are not using too much detergent. no more than 2 teaspoons. try running the unit with no detergent a few times. if problem still persists then check the door seal or remove the door panel and make sure the overflow tray running along the base of the door where the hinges are is not blocked with food. also check the door is closing enough to seal,the door latch may have moved. check the tightness of the screws
Nov 20, 2009 | Miele 24 in. Novotronic G851SC Plus...
I have a Miele G841 SC Plus Novotronic Dishwasher. The Intake/Drain light is blinking and it won't work. What do I do?
I had a problem where my G842Plus dishwasher would run through the prewash and then the intake/drain light would start blinking and it wouldn't work. There would be water in the bottom of the dishwasher. After cleaning out various items to no avail, we called Miele technical support and they told us to reset the codes and then keep trying it over and over until it worked.
Here is how we reset the codes:
  • Turn dial to stop/off
  • Turn dial to Normal Plus
  • Press Start
  • Press power
  • Then press the start button for one second and let go
Sep 15, 2008 | Miele 24 in. Novotronic G842 Plus Built-in...
G 841
This same problem is posted elsewhere on this site. Probably you need to clean out a valve on the bottom of the machine (inside the dishwasher). Check your manual, or the similar post on this site.
May 15, 2008 | Miele 23 in. Novotronic G841 Built-In...
Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Mar 24, 2008 | Dishwashers
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
