The bass has cut out completly on my pro 15 speakers after a party.
  • 979 Answers
Burnt voice coils or damaged crossovers
Posted on May 01, 2008
My behringer b115 just went off whilst i was playing a gig,i can only hear the highs but no the lows
Either the Bass speaker has failed, wire off the bass speaker or the bass amplifier has failed.
Nov 21, 2014 | Behringer B115D Active 1000-Watt 2-Way...
Sometime they work then cut out, not completely, you can still hear the bass ever ever so slightly?
It sounds like you may have a problem with your sound card , suggest you take your computer to your local dealer and get it repaired.
Apr 01, 2011 | Sony SRS-D21 Computer Speakers
What size box do i need?
Normally a speaker box with a 15- 20 litres capacity should be suffficient but it depends on the size of your car. I would not like to waste the boot area for filling up the subwoofer. hence you can compromise and make a tubular type subwoofer or if your vehicle is a sedan, cut out in the parcel tray. If you are able to make bass reflex, the port must be tuned with a sleeve. or else make an infinite baffle. sometimes this is very good for the low bass performance. design the size structure according to the car size, use good joints/ glue well or else it may sqeak with every bass beats. Hope this helps you. Good day
Jul 12, 2010 | Audiopipe TXX-AP15-BL Car Subwoofer
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
Would a Pyramid 15" subwoofer work for my Yamaha synthasiser?
Do yourself a favor do not get anything Pyramid they are cheap for a reason and you will not get good bass response from them even in a optimal enclosure.If you want nice bass for little money go with lanzar opti 1535D sub you can pick one up for around $265 and will blow away Pyramid any day.
http://review.zdnet.com/product/subwoofers/lanzar-opti-drive-opti1535d-car-subwoofer-driver/33649420
  • Custom Tooled Die-Cast Aluminum Basket
  • COC Composite Cone
  • Jumbo Dense Foam Surround
  • 3’’ High Temperature Dual 1.2 Ohm Voice Coil
  • 100 Oz x 3 High Density Barium Ferrite Magnet
  • Power Handling: 1600 Watts RMS /3200 Watts Peak
  • Frequency Response: 30 - 500 Hz
  • Impedance: Dual 1.2 Ohm Voice Coil
  • Efficiency: 88dB
  • Includes Installation Hardware and Template
  • Packaged In a Wood
  • lanzar-opti1535d.9909657.jpg lanzar-opti1535d.3004946.jpg lanzar-opti1535d.9909658.jpg lanzar-opti1535d.1054589.jpg lanzar-opti1535d.1785277.jpg lanzar-opti1535d.9909656.jpg default.jpg
    Apr 18, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
    What size speakers do I have in my mercedes benz E400?
    I'll assume you don't have the Bose system, or else you wouldn't be looking for new ones, depending on your year. It's either going to be 6-1/2" or 6-3/4" The most popular speaker size — replace your factory speakers with some 6-1/2" car speakers for strong bass and improved clarity. Many models includes brackets that allow them to fit in slightly larger 6-3/4" openings. The 6-3/4" speaker, the largest round car speaker, fits in an increasing number of newer vehicles. They offer more cone area than the slightly smaller 6-1/2", so they add more bass to your system.
    Apr 07, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
    My speaker cone got cut on my ls 15 how do i repair it
    There is special adheasives for that type problem you can send the speaker to Pro Line Music 215-736-8055
    Dec 11, 2009 | Cerwin Vega LS-15 Speaker
    When the bass cut on the speakers cut off
    220 watts RMS x 1 at 4 ohms (400 watts RMS x 1 at 2 ohms)
    the amplifier may be over-driven. are there red protection lights coming on the front panel? Or a loose wire - power, ground, or speaker.
    Dec 18, 2008 | Alpine MRP-M450 Car Audio Amplifier
    Bass module
    You dont have to crank up the volume to hear the bass man. It sounds like you have a bad connection some where. check all your connections and also if the wires are shinning and not dull at the connection point. having carbon or dust there will not help.
    Apr 10, 2008 | Bose Acoustimass 15 System
     Grubhead
    Grubhead
