Question about Adapters.com BT-0333 Bluetooth USB Adapter Class 1, v1.2 NO DRIVERS NEEDED for XP (BT0333)
Driver for bluetooth for win 98
I have a China made bluetooth dongle of Shenzang company, the instalation disk is not read by cd-rom. Tell me how i could make it detect on Win 98 to use it as modem ?
I too have Kings ton data traveller of 4 gb it also not detected by Win98 ?
Post me Driver on my E-mail hello_1987@rediffmail.com
  • 77 Answers
Hi!
1 Was it working before?
2. Is the bluetooth compatible with Win98? Does it meet the bluetooth's minimum requirements?
3. Is your computer an old computer? Maybe your computer's USB ports are USB 1.0 and the 4Gb USB is USB2.0. This I believe will be incompatibile.
4. Try those USB adapters at a different computer to further isolate your problem.
Hope these info helps!
Posted on May 05, 2008
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Apr 10, 2013 | Computers & Internet
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
Laptop stopped booting
It is dead... give it a decent burial... win 98 is not functional anymore...
Jan 10, 2013 | HP Compaq Business Notebook NX9010
Cd rom will not read. have just put windows 98 on instead of xp, hard disc was formated, have win 98 now, but cd wont work or if i plug in usb memory stick
With Windows 98 you MUST install a suitable driver in addition to Windows 98 to talk to CD Roms. I believe there is also a general service routine that must be loaded.
XP has all this functionality built in.
Try this site to solve your problem:
http://www.computerhope.com/download/hardware.htm
Nov 07, 2009 | Acer Aspire One PC Notebook
Instalation of windws 98
Change your bios setting to boot from cd. restart, choose start with cdrom support and follow the instruction
Mar 14, 2009 | Microsoft Windows 98 for PC
HOW TO INSTALL WINDOWS 98
How to Install Windows 98 loadTOCNode(2, 'moreinformation');
  1. Insert the Windows 98 Startup disk in the floppy disk drive, and then restart your computer.
  2. When the Windows 98 Startup menu is displayed, choose the Start computer with CD-ROM support option, and then press ENTER.
  3. If CD-ROM support is provided by the generic drivers on the Startup disk, you receive one of the following messages, where X is the drive letter that is assigned to your CD-ROM drive: Drive X: = Driver MSCD001
    Drive X: = Driver OEMCD001 NOTE: If your CD-ROM drive is not available after you boot from the Windows 98 Startup disk, install the CD-ROM drivers that are included with your CD-ROM drive. For information about how to obtain and install the most current driver for your CD-ROM drive, view the documentation that is included with your device, or contact your hardware manufacturer.
  4. Insert the Windows 98 CD-ROM in the CD-ROM drive, type the following command at a command prompt, and then press ENTER X:\setup where X is the drive letter that is assigned to your CD-ROM drive.
  5. When you receive the following message, press ENTER, and then follow the instructions on the screen to complete the Setup procedure: Please wait while the Setup initializes. Setup is now going to perform a routine check on your system. To continue press Enter.
Jan 21, 2009 | Microsoft Windows 98 for PC
I have just bin an bought a bluetooth usb dongle with the instrlashion disk an it starts to install then it stops an askeds is to insert the disk but it isnt reading the disk an say to search the internt...
for installing the blue tooth , first insert the cd and run the setup don't attach blue tooth device at this time,
it will insall drivers, check continue any way option, after that plug in the blue tooth dongle, if again it will ask for driver check continue any way option, do it
how do you like the solution please rate it
Oct 14, 2008 | Computers & Internet
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Can I get the software on floppies?
A CD-ROM would initially be required to create floppy installation disks. This option will require 6 disks for Windows 3.x, 9 for Win 95, 98 and NT or 8 disks for a Mac installation.
Sep 13, 2005 | Epson PhotoPC 600 Digital Camera
Adapters.com BT-0333 Bluetooth USB Adapter Class 1, v1.2 NO DRIVERS NEEDED for XP (BT0333) Logo
129 people viewed this question
Top Adapters.com Computers & Internet Experts
JP Services
JP Services
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
