Kenwood 7300 amp preamp volume control needs replacement
  • 1,512 Answers
Hi Dave
Have you tried floooding the internals of the vol control with a contact lubricant spray... CRC2-26 is my favourite magic fix for noisy controls.
regards
robotek
Posted on May 02, 2008
How can i hook up my kenwood stereo control amplifier KC-105 to my GPX home stereo system?
If the GPX has an headphone output you could use the a stereo headphone jack to two phono cables lead. Connect them to the "aux" socket of the amp, or another suitable - not a phono or deck - socket.
You would have to keep the volume level low on the GPX unit, but apart from that all the functions should work.
Aug 04, 2015 | Kenwood Audio Players & Recorders
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
Kenwood amplifier a-58
Follow the connections inside the unit of the volume control. They should lead you the volume and tone circuits. You will probably see (if you follow the PC board tracks) that they lead to an IC. These generally control all the sound functions. You might need to replace the IC.
May 05, 2014 | Audio Players & Recorders
Kenwood
I'm assuming 'Kenwood' means a home stereo amp or receiver? If so, the volume control probably just needs to be cleaned. Control cleaner can be purchased at Radio Shack, or a similar store. Just buy a can, and spray a tiny amount into the control, and turn it all the way clockwise then all the way counterclockwise several times. If that doesn't correct the problem, the control may just be worn-out and is in need of replacement.
Apr 28, 2013 | Audio Players & Recorders
My Kenwood A-51 amplfier won't play music when connected to speakers.
http://www.agtannenbaum.com/k_cat.htm#KENWOOD manual here..........meder's tv service
Sep 10, 2012 | Kenwood Audio Players & Recorders
How can I conrol the volume of bose sa 3 amp from the aux input ?
That would depend on the preamp. Name it. A true preamp outputs a variable signal.
It's not clear from the manual what the state of the volume output is without the VCA. Most amps default to full ON and the preamp attentuates the signal with a volume control. Try it with a signal that fades in slowly so you can intervene if it gets too loud. If it's full ON a preamp will control its volume.
May 28, 2010 | Bose Lifestyle SA-3 2-Channel Amplifier
7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Jan 06, 2010 | Onkyo M-282 2-Channel Amplifier
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
Nov 15, 2008 | JVC RX-E100 5-Channel Amplifier
Marantz AC 500U
Hi
Sorry for the delay in getting back to you, you have an odd problem happening there, the pre-amp being the common denominator to the syptoms. Perhaps you could try reducing the attenuators to say 60% and retry at the same levels you used to use at the preamp. It is unlikely that there is a fault occurring that would increase the output of the preamp, more likely to be a DC component getting through. It could also be possible that the amps if all the same make and model have through over the period of installation developed the same fault.
There will have to be a common contributor to the symptoms. It is not uncommon for the same problem to affect a particular model at the same point of its life. Best approach and easiest to fault find it would be to change out the preamp with something similer to test the system and see what happens. At least tyouy will know where to start looking. Hope I have been able to help you, still happy to discuss it further. In the Free section our only reward is a FixYa ratings. Cheers
robotek
Jul 13, 2008 | Audio Players & Recorders
Open Questions:
139 people viewed this question
 Grubhead
Grubhead
