Question about Vacuums
My bissle proheat carpet cleaner/vaccuum has become clogged with the cleaner solution. As a result the cleaner solution does not reach the carpet when in operation. I had this fixed before at a local appliance store but they are now closed. I would like to do it it at home. Is there is simple solution to clean the system so it becomes functional.
  • 3 Answers
Take apart the handle (a few screws) unclip the small clear hoses, use a pipe cleaner or small screwdriver to clear the hose from the crystalized cleaning solution that is blocking the hose. Put it back together and it will be like new. ALWAYS run plain water through your machine when you are done using it to rinse it out.
Posted on May 01, 2008
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Where will I find the user instructions for swan carpet cleaner scw3011
Search Results
    How do i use my Swan Carpet Washer SCW3011 once its ...
    www.fixya.com > Forum > Kitchen Ranges
    Aug 7, 2011 - Bissell ProHeat Perfect Pass carpet cleaner. The cleaning solution container never empties. We run the cleaner all over the carpet and still ...
Oct 08, 2015 | Vacuums
My bissell proheat 2x dual dirtlifter is not succioning very well then the carpet smells
We have several parts here for the Proheat 2X,
Proheat 2X Shampooer Shampooer Parts
It may be a clog in your tank, preventing the water being sucked back up. Check your tank and tubes for clogs or damage. Make sure the brush is still rotating and the belt is not broken too.
800-775-6586
GoodVac com
Feb 26, 2015 | Bissell 2X Proheat 9200 rug cleaner
Bissell Carpet Cleaner Won't Release Solution...
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
h
Sep 25, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Since the last use of my new ProHeat X2 carpet
Check the lint filter. It is located in the top clear plastic section (the one with the dial to switch from floor to tool mode). On the underside of this section is a small (about 1 inch square) red plastic piece with a little door on it. Flip open the door and you will probably find it is clogged. Clean it out and you should have full suction again.
Sep 19, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Will not dispense water how do I trouble shoot bissell proheat steam carpet cleaner
Listen to see if you can hear pump run when pressing button, if the pump does run, than either you have a clogged nozzle or screen in water fill compartment.
Jun 22, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
The bissell proheat turbo carpet cleaner is not sucking up water.
heatman101
jer
Jun 08, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Bissle carpet cleaner
Yeah....I did all that too....nothing!!! I called to have mine repaired. They said it sonds like a clogged heatercord?? I tired to look up what that was...can't find anything about it!!! ERRRRR!!!
Aug 07, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissle will not let water out if Bladder
Check the vale at the bottom of the tank. Push it in and see if water comes out ok, also check to make sure the seal is on the valve asm. Check the pump belt to see if it broke. Could have a bad pump. Is the top cover seated against the base in the back, if it is raised up, then it also raises the tank so it can't work.
Apr 12, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
129 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
