Dell e310 computer
I turned my computer off before a storm came the other night and now it will not turn back on. I had it on a power strip as well. I have a power supply tester and everything starts kicking when I plug it in but when I plug back into the motherboard I get nothing at all. I also checked the power button to make sure it wasn't worn out and not connecting. The only thing I can see is an aolid amber light on the motherboard next to the battery. It says it is the aux_pwr light. what does this mean? I am pretty sure my mother board is dead, is there anything else I can do to check it? Thanks
  • 8 more comments
  • nbiagini May 01, 2008
    Not that I can see, the only light that is doing anything is that aux_pwr light on the motherboard
    I could not see any brand on the motherboard, but it is a intel 915 chipset motherboard. Nothing turns on when I plug it in. The only time anything starts up is when I disconnect the power from the motherboard and plug it into a power supply tester. Then all the fans and such kick on. But when the power is attached to the motherboard nothing will happen at all.
    yes, I'm plugging the PSU into a tester and when that happens the fans and such come on. So the PSU is dead even though it comes on when the tester is plugged into it?
    thanks, that is kinda the path I was thinking of, but just thought I would see if there was anything I missed. On a side note, do you know what the aux_pwr light being on means? I cannot find any documentation on what that could mean. Thanks again
    Thanks, I already went through that support page at dell. None of that applies to what is going on.
  • Jason May 11, 2010
    Sorry, I meant to comment on "Then all the fans and such kick on. But when the power is attached to the motherboard nothing will happen at all."
    Ok, so PSU into tester, PSU fan spins. PSU into motherboard and outlet, nothing happens. You've got options.
    1 - You can try swapping the PSU (if you have a spare; don't go buy one as it seems like it's really ok)
    2 - Disconnect everything from the power except the motherboard. So disconnect your hdds, rom drives, etc. If nothing happens still...
    3 - Buy a new motherboard. We can figure that out after.
    I assume you mean you're plugging the PSU into a tester? But if the PSU fan doesn't start to spin when you hit the power button, and it's plugged in of course, then your PSU is dead.
    Happen to know what brand motherboard it is? You might be able to find that printed on the board itself somewhere around the processor.
    Also, when you plug the computer (and by that I mean when you connect the power supply unit (PSU)) into the electrical bar and turn it on, does the PSU fan turn on? Let's start there.
    Is there a light on the power supply itself?
  • chris Rohrer
    chris Rohrer Sep 19, 2013
    no the fans are coming on when the computer powers on
  • 77 Answers
It's just a standby light, that the board is receiving power when the switch on the psu is turned on.
Check out this page and let me know if you see anything relevant on your machine:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1130520
Posted on May 01, 2008
Dell dimention E310 green light will go on and off
You turned off the surge protection....Ummm did you remove the plug from the wall after doing this?. If you did then it has become corrupted due to a bad shutdown meaning that the system had not fully shutdown when power was turned off which has corrupted the data stored on the MBR ( Master Boot Record ) but I do not understand why you can not restore from a previous good known configuration. If you have a recovery disk or windows os boot disk try to repair it, if it will stay on long enough that is.
If you turned off the surge protection and did not remove the plug from the wall because you turned off the surge protection it is not available to protect your devices etc and in turn a lightening strike close enough will fry the computer due to EMP ( Electro Magnetic Pulse )
You may need to have a qualified person look at it but if it has been fried due to EMP sorry to say but you can say goodbye to the computer as it will not be repairable, You may be able to reuse the case as long as you use another Dell motherboard as Dell have an unusual way of mounting the M/B ( Motherboard ). I hope this helps.
Oct 18, 2012 | Dell Dimension™ E310 PC Desktop
My Acer Aspire M1201 won't turn on.
More than likely your power supply got fried from a power surge during that storm anyway. You'd be surprised at how worthless most surge suppressors are these days.
Jul 25, 2012 | Computers & Internet
Cpu fan stopped working on dell dimension e310
Did you accidentally knock the fans little power plug out of its connection to the motherboard?
May 17, 2012 | Dell Dimension E310 PC Desktop
I have a Dell Dimension E310 with the power button flashing amber. I recently replaced the power supply due to an electrical storm, good reason to suspect the power supply. But the only way to get past...
i suggest using a PCI ethernet lan card with drivers cd. this should allow the bypass of the integrated connection to be that of the newly installed device.
Jan 17, 2011 | Dell Dimension E310 PC Desktop
My dell dimension computer won't turn on. When I push in the button, it only flashes orange and then won't turn on.
Plug the computer into a power strip that has an on/off switch. Turn the power strip on. Press the computer power on button to start as normal, but after after one second turn off the power strip switch just long enough for the fans on the computer to slow down, but the amber computer led doesn't turn off and then turn the power strip switch back on. Computer should start and run fine. Computer typically can be shut down for up to 5 minutes and restarted normally--any longer and you have to sue the power strip power switch routine again
Oct 25, 2010 | Computers & Internet
My dell e310 will not turn on
Check the power cord make shure both ends are not loose. Check the switch on the back of the tower. If the computer is pluged in to a power strip check the surge protector most have lighted switch and a reset button. If no power at the wall outlet check that a wall switch doesn't control it and is on. Check circut breaker Or fuse pannel.
Hope This Helps
Please leave feedback
Nov 16, 2009 | Dell Dimension E310 PC Desktop
My dell dimension e310 will not power up at all
If by "reseat" you mean "reset," I'm not clear whether the problem is hardware or software.
If the machine won't turn on, check that the power cords to the computer and monitor and the video cable between the two are all firmly connected at both ends. See if there's a power switch on the back of the computer near where the power cord connect - if so, make sure it's on. Press the power button on the front of the machine, and write back to let us know what happens.
If the machine works fine but you're trying to restore it to factory-default settings, enter your service tag number on Dell's support Website and search for directions there.
Let me know if you still need help, or see our Website for other tips: MaverickSolutions.biz
Jul 21, 2009 | Dell Dimension E310 PC Desktop
Hp psc 2200 printer will not turn on.
If connected to a power surge protector, turn the protector strip off / on.
Jun 10, 2009 | HP PSC 2210 All-In-One InkJet Printer
Dell E310 Dimension that won't go on!
Boot the computer into safe mode. Run full-system anti-virus scans to ensure that the system is virus free and to remove any infections that may be present. Reboot system.
Instructions for booting into safe mode:
1) Start system
2) As system is starting, press F8 key
3) Boot menu will come up asking how you want to boot - choose Safe Mode and press ENTER
4) Your computer will start with limited services, no internet connection, etc. This will allow you to check the system and scan for viruses without interference from non-essential services.
Let us know how it turns out.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | Dell Dimension E310 PC Desktop
COMPAQ Presario v6000 dead, Period
Hi there.
Remove the battery and try it on AC power only, if it boots up turn it back off and put the battery back in again and power it up again, if it boots up, the cause will have a small surge from the power strip caused by the thunder storm.
Good luck and thanks for using Fixya!!
Feb 27, 2009 | Dell Latitude L400 Notebook
Computers & Internet Logo
766 people viewed this question
David Payne
David Payne
