Question about Philips DVDR3380/05 DVD Recorder
Blocked dvd I have the above machine, and 'blocked' appears on menu, unable to open machine totally frustating please help have tried turning off etc and next time the knife...
  • daviddo Aug 22, 2008
    blocked is appearing in window
  • 42 Answers
It seems to be a gear problem within the DVR.
Let me point you to another thread about a similar problem.
http://www.fixya.com/support/t216507-eject_tray_will_not_open_when_pressed
Read through this one might work for you.
Hope this helps. M~
Posted on May 01, 2008
Maytag dishwasher model mdb7100aww, no water input,all else appears ok
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working). Please rate this solution.
May 21, 2011 | Maytag Dishwashers
Keep hanging up in wash cycle
Please report all error codes and try to time where in the cycle it is happening. The reasons it might hang are waiting for water due to blockage, unable to drain due to pump or outlet pipes blocked, unable to heat as heater/ thermostat faulty, door showing as open (even though it isn't), motor not turning when it should etc etc. You haven't given enough info or model number, to diagnose.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | LG Washing Machines
MY DVDR3380 TRAY WILL NOT OPEN, SAYS ITS BLOCKED
I had the same "Blocked" problem and solved it - by using a rubber band! Unplug the machine and take off the outer cover. Remove the DVD reader and take off the cover to the reader - you can now easily recover the DVD that was stuck in the machine. Now slide out the actual DVD tray, you will have to bend back a couple of restraining bars to get the tray out completely. You should now see a small white wheel which is actually the end of a concealed electric motor. There will also be a larger black pulley which controls the movement of the DVD tray. If there is no band connecting the pulley and the white wheel, that is your problem and I solved it with a small elastic band. Put everything back and turn on, wait for all the messages to clear and press the eject button - the tray opens simples. It has taught me never to force the tray in manually, but to always use the eject/open button.
Aug 22, 2009 | Philips Televison & Video
Dvdr tray
You have one of the following problems:
  • The device freezes and does not react anymore to the remote control commands.
  • The DVD is stuck in the tray. Sometimes the message BLOCKED appears.
  • A feature is not available in the menu without any logical reason.
  • A feature of the device does not work (for example start install).
  • There is some problem with the device you cannot solve.
Reset the DVD recorder.
  1. Unplug the mains cord from the mains wall outlet.
  2. Press the POWER/ON button on the DVD recorder itself.
  3. While keeping the POWER/ON button pressed connect the main power cord to the wall outlet again. A message IS TV ON? or a demo message will appear in the display.
  4. Start the first installation process.
Notes:
    1. The settings of the DVD recorder will return to their default settings. Install the DVD recorder as if it came out of the box.
    2. The data on the hard disc will not be affected.
Apr 28, 2009 | Philips DVDR7260H DVD Recorder / HDD...
Washing machine door blocked
Try to unplug the unit for 10 to 15 minunets, the washer may reset its self to default mode.
Feb 13, 2008 | Whirlpool AWM6120 Front Load Washer
WD440 conditioner inlet /outlet appears blocked
Hotpoint WMA36 Washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2008 | Washing Machines
Trying to ventilate and hot water not flushing through on button 26
Before you press water button to vent you need to restore to factory settings.
First press menu (far right button) then toggle to restore factory settings (using far left button), press menu button then far right again until yes comes up, then press menu button. Press esc button (3rd from left), machine should now be back to normal. Then press water button (3rd from right) and turn steam knob to vent until free water is coming through.
This is the only way I could get mine to work!
Dec 30, 2007 | Gaggia Titanium Espresso Machine
the most common cause of this problem is a faulty design of the detergent tray, the conditioner works on a syphon system after you feel it up a little bit water is added to it to make the syphon action, either the little wholes above the soap tray are blocked or the soap tray may need cleaning
Dec 16, 2007 | Hotpoint Aquarius WD640 Front Load...
"Protection Error"
the DVD is blocked in PAL system, ¿ How I can the DVD in NTSC system ? the menu is blocked. thank
Sep 24, 2007 | Toshiba SD-43HTS System
Philips DVDR3380/05 DVD Recorder Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
