Question about Cameras
No pictures I have a new Pentax Optio S10 with a Transcend 2GB sd card, which was correctly installed and formatted. I took several pictures which played back fine on the LCD screen. When I attempted to view them on my pc I get the message: there are no images on this device to aquire. The software recognises my camera as an s10, but whatever software I use I get the same messege. Could the sd card be faulty?
  • 2 more comments
  • slaphead2 May 02, 2008
    I tried the camera on another PC same problem.
    How do I do that in XP Pro?
    What I mean is how do I format the Sd card through through my PC using XP Pro?
  • slaphead2 May 03, 2008
    Problem solved. Thanks very much.
    Genius:
  • 3,422 Answers
HI,
The sd card is not being recognized by your PC.Do one thing try it out on another PC and see if it is recognized and that your able to see the pics.If everything goes fine ona another PC then it is not the fault of your camera or sd card.Its your own PC..You can go for a system restore but you will loose all your data on your PC.So make sure you take a backup and then go for it..
To do a system restore got to START>PROGRAMS>ACCESSORIES>SYSTEM TOOLS >SYSTEM RESTORE
Goodluck,
Please don't forget to rate the solution.
Posted on May 01, 2008
  • Priya darshan May 02, 2008
    Do you have a card reader in your PC or laptop.If yes just insert the card in it.Once you format it you will loose all your data so please take a backup.
    1. Put the SD card on your PC using a card reader or USB adapter
    2. Go to a command prompt (Start -> Run -> Cmd)
    3. At the command prompt type format X: /fs:FAT /a:32K
    NOTE: X is the driver letter of your SD card
    This does a full format (not quick) to FAT16 with 32k clusters. This seems to be the best options for a 2GB SD card.
    Please don't forget to rate or accept the solution
    Brigadier General:
  • 6,966 Answers
it is possible that for some reason, the formatting of the Transcend 2GB SD card (as done in the camera) was not recognized by the PC. Have you tried formatting the memory card through the PC first before using on the Pentax Optio S10? IF not, could you possibly pls try and post back results?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 02, 2008
    Hi slaphead2,
    An alternative to coolguy008's second posting/solution and in the absence of a memory card reader, you can still format the memory card while in the camera through the PC. Connect the camera to the USB port of the PC. In "My Computer", the memory card would appear as an "External Mass Storage Device", right click on that and one of the drop down options would be "Format". Do a full FAT16 format.
  • Louie  Role
    Louie Role May 04, 2008
    Glad to be of assistance and appreciate the rating too.
Im using an optio s4 camera and just bought a 4GB SD card. But when I insert the SD card into the camera, there's only a black screen when I turn it on.:( But when I remove the SD card, the camera works...
The Optio S4 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to go with cards 2GB and smaller.
Jan 15, 2011 | Pentax Optio S4 Digital Camera
SD card problem
here is a list of compatable memory cards
http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=42425
.. any SD or MMC card should work up to 4 gb ... so your 2gb should be ok .. i suspect that it may be damaged .. you can try formatting it in a USB card reader if you have one on your computer .. some laptops have the SD slot built in .. there was some compatability issues with memory cards for older cameras but there shouldnt be any with such a new machine .. make sure the contacts are clean and the "protect" switch (if any) is in the unprotected mode .. when you format the card it may take several minutes so give it time .. if you are going to take movies then its better to use a "high speed" SD card .. like the 133x mentioned in the above URL .. slow memory may cause missed frames or 15 fps instead of 30 fps record rates.. .
the specs on your camera do show SD and MMC compatability .but they dont show any brand preference .. .
Oct 06, 2009 | Pentax Optio 33LF Digital Camera
Camera won't read new SD card
The sd card is to big go for a 2gb ted10
Apr 18, 2009 | Pentax Optio 550 Digital Camera
Problem transferring pictures to PC
do you have the ability to attempt transfering the pictures onto another computer  maybe its just that computer  what type of card reader are you using  is it factory installed or aftermarket try installing a different card and see it you can transfer pictures from your camera to the computer then  maybe its a file type(format)problem  theres what i have good luck   let me know how it goes
Mar 28, 2009 | Pentax Optio A10 Digital Camera
SD memory prohibits functioning of Pentax E30
I know that usually, you should format the card for the camera that your going to use. Try formating it in the camera and see if that works. Let me know if I can do anything else for you,
Rob
Feb 22, 2009 | Pentax Optio E30 Digital Camera
Kodak 4 GB SD card (brand new) shows "card error" in Pentax optio
Hey,
The problem is your camera doesn't work with the 4gb card, its too big. Sorry!
Your stuck with 2gb cards. Id suggest to echange the card to two 2gb cards.
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | Pentax Optio 30 Digital Camera
Largest capacity SD card for Pentax Optio S5N
The maximum supported size is most likely 2GB SD Card. Cards with 4GB and more are following a new (incompatible) standard called SDHC (SD High Capacity), SDHC cards work only in devices specifically supporting SDHC. The Optio S5N uses the old SD standard where 2GB are the maximum size.
May 17, 2008 | Pentax Optio S5n Digital Camera
SD memory cards - and how smart are these cameras, really?
I use 2gb cards in my Optio W10 and format them regularly on my camera every time I am finished transferring the pictures to my hard drive.
Mar 06, 2008 | Pentax Optio W10 Digital Camera
Pentax Optio S not functioning
I don't know if it would help but try to update the firmware for the camera.
Jan 01, 2008 | Pentax Optio S Digital Camera
Cameras Logo
65 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
