Question about Insignia IS-LCDTV32 32 in. Television
Closed caption I am really frustrated, I can't get the Insignia to show closed caption. hen I use the ccd button all it says is "no cc programmed". We are using a cable tv line with a cable box, can you help? thanks
  • dajemail Mar 19, 2009
    I have an insignia 26 in tv/dvd combo which is about a year old. I was getting the closed caption but it stopped. I go to the menu settings and closed caption option is grayed out and can not be selected. However, when I bypass the comcast cable box and hook the cable directly to the tv it is no longer grayed out but when I turn it on it still doesnt work doesn't work.
    Problem Solver:
  • 9 Answers
It's all in your menue set up and you need to call or go online to the company for the solution, using your remote to reprogram it correctly. You need to set it differently than cable...I "think" you have it set twice and it basicly doesn't know what to do. It may be seeing it as directly to TV and so the Cable setting would be the wrong setting.
Posted on May 06, 2008
Insignia. How can I disable closed captioning (CC)?
If your Insignia remote has a CC button, try pressing it. If not, return to the initial set up procedure and disable it there.
Feb 25, 2016 | Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see it..as "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
How do i delete closed captioning?
The button marked CCD "close caption display"
BTY if the TV programing is coming via cable box that the CCD feature needs to be turned off in the cable box under settings. If there is a cable remote the CC will usually be near to the "cable" button
26052381-dbyvlhzmxmckmsztft4cqgrd-4-0.jpg I hope that this helps?
Jan 13, 2016 | Dynex DX-L19-10A LCD TV
Need Closed Captioning
If you have the original remote control, there will be a button marked "CC", and pressing it once, the closed caption funciton will turn OFF, and for an other press, it will re-appear. Now, here you are using a universal remote control. So it will be difficult to make closed caption. Try to enter its function menu by using present remote control, where you can make this funicion OFF, if you could enter into it.
Jun 02, 2013 | Insignia NS-RTV32 32" TV
How to turn off the close caption on tv
Hello
Not all TV programs and product
commercials are made with
Closed Caption (CC) information
included. Neither are all Closed
Caption modes (CC1, or CC2) necessarily
being used during the transmission
of a closed caption program.
Refer to your area's TV program listings
for the stations and times of
Closed Caption shows.
To close the close caption display from screen; press "CC" button on the remote control.
Jul 08, 2011 | Philips Magnavox 20MT133S 20" TV
There is a black box, right in the middle of my screen when watching abc programming--doesn't appear during the commercial breaks--
Hello
Closed caption function in your tv is now switched ON. Turn it OFF. You can do it by pressing the [CCD] button (Closed Caption Display) button on the remote control.OK.
Feb 14, 2011 | Insignia NS-14FCT TV
My closed caption on my new dynex 26L 150A11 will not turn on. I have followed all instructions in the book. I need the cc. any one have an answer? thanks cosycat
There are several possibilities here so you will need to work with me to resolve this problem. In order for Closed Captioning (CC) to work, you need to make sure the CC settings are correct on the TV, and then make sure they CC is switched on. In addition, if you are using a cable or satellite receiver box, CC also needs to be switched on for these "boxes".
It's easiest to start with the TV. Please make sure you have done the following:
1. Check the Closed Caption settings are as follows from the TV on-screen menu as follows:
a) Press the "MENU" button on the DYNEX remote
b) Press the RIGHT arrow twice to highlight the "SETUP" menu
c) Press the DOWN arrow once to open the "SETUP" menu
d) Press the DOWN arrow twice to highlight "CLOSED CAPTION"
e) Press the RIGHT arrow or the "ENTER" button once to open the CLOSED CAPTION MENU
f) Make sure the Closed Caption option "CC MODE" is set to "ON". This can be changed using the UP/DOWN arrow keys to highlight "CC MODE" and using the LEFT/RIGHT arrows to switch between off and on.
The "Basic Selection" and "Advanced Selection" settings are for analogue and digital closed-captions respectively. In addition, the "Options" sub-menu can be used to change the size and style of the digital closed captions (Advanced Selection). All three of these options should eventually be set according to your personal preferences, but for the purposes of making sure it is working, I suggest you set them as follows:
Basic Selection = CC1
Advanced Selection = Service 1
These options are the basic settings which will display only the spoken dialogue of the TV program.
g) Press "EXIT" on the remote to close the menu and return to viewing mode.
2. Press the "CCD" button on your Dynex remote control. This can be found in the bottom right-hand corner of the remote. Each press of the "CCD" button will cycle the closed captions between ON and OFF. (CCD means Closed Caption Display)
3. Check the Closed Captions are displayed and then adjust the Basic and Advanced Selection options until the type and appearance of the closed captions are how you like them.
If you have done the above and still cannot get it to work, please let me know whether you are using a cable or satellite receiver and the brand/model number. I will then be able to assist you further.
Regards,
BElectric
Dec 30, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
How do i turn on the subtitles on my tv
On your remote control look for a button that says CC for Closed captions. If some screen (CCD) with choices appears, use the [Arrows] to try them one after the other until captions are displayed. Beware that some programs do not show captions. News programs usually do.
Hope it helps
Sep 05, 2009 | Polaroid Televison & Video
Insignia IS-LCDTV32 32 in. Television Logo
269 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
