Question about Samsung SCX 4200 All-In-One Laser Printer
Have a sumsung printer/fax/copier model # SCX-4521F and I am getting an error (Open Heat error) it will not print from my c omputer or print my incoming faxes, what do I need to get done.
  • 1 more comment
  • Anonymous May 22, 2008
    Please describe the specifics of your problem below. We'll add
    your post as a comment to 42Brent's Have a sumsung printer/fax/copier model problem, and notify you when a new solution is offered.
  • Anonymous Sep 11, 2008
    please send me the solution asap,
  • corarey2000 Sep 12, 2008
    on the dell it says (OPEN HEAT ERROR) fax waiting
Where exactly are the two heavy wires and the fuser?
Do we have to open the to the copier?
Posted on Sep 12, 2008
    thank you for your assistance
    this is wonderful.
The Dell 1600 is made by Samsung, so all posts explaining this problem for Dells apply to your machine also.
If I understand correctly, the Open Heat error indicates that the sensing circuitry for the fuser has detected that the fuser is not heating up. This can occur because either the sensing circuitry isn't detecting correctly or the fuser actually isn't heating up. Probably the latter in most cases.
How to fixya? Probably install a new fuser and you'll be fixed. Want to be sure before you spend $$ ?? Pull the fuser out. You will see a wiring hookup with two heavy wires that supply 110V to the heating lapm. Connect an ohm meter across the two wires that are on the FUSER. A good fuser will read around (0) ohms - complete circuit. A fuser with a bad lamp or a bad thermostat will read infinite resistance (open circuit).
The thermostat is probably available as a separate item. It's probably about $15 from several online sources. I believe you will need a JC47-00013A. I could be wrong. You'll need to do some research if you find that to be the problem.
Posted on May 11, 2008
The printer spooler not runing printer name sumsung scx-4521f
The printer spooler is a service on the computer.
To turn it on you open a command prompt (run, cmd, enter)
Type: net start spooler
Aug 09, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Open heat errors
Clean thermistor of dirt or Disassemble fuser and inspect thermistor, thermostat and heat lamp. Replace broken part.
Jul 31, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Open heat error in my printer model SCX-4521F
open heat error sounds like the fuser lamp is blown. The fuser lamp is inside the hot roller at the back which melts the toner onto the page. It is not really a user serviceable part, you would need someone qualified to repair/replace the fuser.
Apr 28, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Scx-4521f fax not sending and not receiving
4521f printer fax receive but not print so whats your problem
so plz solve this problem
Mar 25, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How to print fax stored in memory, model scx-4521f
I had ten same problem and I also had the toner empty message. I followed the help from http://www.fixya.com/support/t4256332-remove_toner_empty_message anf my fax was back in the business. It start to print everything from memory. Hope it will help you too.
Feb 25, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Printer is not working despite of installing driver from web.
Oct 05, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax Machine Samsung Model SCX-4521F
Kindly update me Is it printing/Copying working properly.
This issue with printing part. Kindly clear memory. Check Cartridges.
Sep 04, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX5115 printer
I have a samsung lazerjet scx 4100printer,My printer problem is heat open error after power on,ple help me
Nov 30, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
292 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
