Question about Acer Aspire 5050-3242 Notebook
Installing xp Hi,        I just want to reinstall xp, but the screen got complety black after showing "Set up is detecting your hardware." I have also installed Fedora 6, but that works fine.
  • Prashant Mak May 20, 2008
    no, i have single memory.Should i uninstall fedora and then reinstall Windows xp
  • 111 Answers
If you have more than one memory, try to remove one and install XP. If the first memory that you used gives you same result, try to remove and use the 2nd memory.
Posted on May 20, 2008
  • Prem Chugani May 20, 2008
    If you only have on memory try to clean the connector of the memory using a pencil eraser. Then try to run the Xp instalation again.
    Please avoid voting yet, if you still intend to ask question and expect answers from us.
    Thanks.
Re-installed XP Pro + SP2 + SP3 - but have black screen
reinstall xp and dont install sp2 go to microsoft update and let it install sp3 for you
Sep 23, 2009 | Dell Latitude D600 Notebook
Brother DCP165c Driver installation Problem
I would boot in safemode (hold down f8 immediately when it starts (when it says Starting Windows xp), then delete all printers (associated with this) in device manager.
remove any printer software as well (add remove programs or start programs (printer program name, remove software IF listed),
also remove the port you are using in device manager be it lpt or usb. if the drivers siuggests installking without it connected do so, otherwise, just restart and it shoudl start installking the hardware amnd software it finds. be sure you have the correct drivers ready as well>
Good Luck
Jul 09, 2009 | Office Equipment & Supplies
HP Compaq NC6220 won't boot
I'm running into the exact same issue. Were you able to resolve the situation?
Fatima
May 16, 2009 | HP Compaq nc6220 Notebook
Hard drive failure required rebuild of XP Home on Dell computer. XP Home updated to SP3. Canon Multiplass F80 printer will not now work. I downloaded latest XP drivers from Canon web site, but installation...
I found that some Windows Plug and Play services were note running and were set to start 'manually'. I started those services which seemed related to Plug and Play, and the installation went without further errors.
May 11, 2009 | Canon MultiPASS F80 All-In-One InkJet...
MY USB(2.0) PORT NOT WORKING
hi,
welcome to fixya.com,sir if u have already uninstalled and reinstalled the drivers and if u have already reinstalled the operating system and if it is still not working then simply replace the system motherboard.
Feb 14, 2009 | Microsoft Windows XP Professional With...
I install brico pack(themes or xp) after some days i download servicepack 3 from internet and istall that to my pc. install sucessfully, but after restart windows diint get in i just see black screen ony.....
Follow the steps given below to resolve the issue.
1. F8 at system startup.
2. Boot to safe mode with command prompt.
3. Perform a system restore.
For instructions on how to perform a system restore from Safe Mode with Command Prompt use the link given below: http://support.microsoft.com/default.aspx?scid=kb;en-us;304449
If this fails do a system restore from Recovery console.
Jan 22, 2009 | Microsoft Windows Vista Ultimate Edition
No Sound After Reinstall
Have you Reset you BIOS,because after you build a machine up,the Bios has to be set to Default,and were you grounded with a arm band when you put the parts together?,During the assembly it is paramount that you wear a grounded arm band so that your body electrical discharge does not interfere with the components,you probably have a hardware/software conflict.some thing in the BIOS is most likely left on.or set to hardware.
Dec 14, 2008 | Biostar P4M890-M7 Motherboard
Logitech QuickCam1150 Notebook Deluxe camera not configured properly in xp error
Hi, Please uninstall any logitech software version present on your OS (if available) - Then please proceed to clean boot. ( http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=228 ) -> Unplug all the USB devices connected to the computer ( Less keyboard + mouse ) please use corded kbd+mouse if
possible rather than a cordless device. -> Go to device manager -> Delete all the USB HOST CONTROLLER -- All of them -- -> The host controller might reinstall them itslef, let the computer handle the reinstallation -> If the computer does not reinstall the host controllers, trigger the detection using the DM function " Scan for
new hardware " ( The computer with magnifier icon ) -> Once reinstalled, clean boot -> Reinstall the software if available and/or plug the hardware when needed. -> Should work.
This TB delete the usb ports " memory " means if a device as been previously flagged with error, it will redetect
the device without the flag, unless there is some serious issue with the hardware/OS
If after this the issue persist, then I suggest you to call Logitech support to issue a replacement, hardware
failures are covered by warranty terms
US/Canada support: http://www.logitech.com/en-us/contact
European support: http://www.logitech.com/en-gb/contact
Thanks and have a nice day ! J -
Nov 10, 2008 | Logitech Webcam
Audio Hardware Detection
check the website for newest drivers if not you have to reinstall then install sp3 and hope your drivers work again. or just stick with sp2.
Jul 02, 2008 | ASUS P5VDC-MX Motherboard
The motherboard cannot detect the hard drive/ hard disk
You cant install xp on one machine and then move the drive to another. By nature the xp install is tied to the hardware of the machine it is installed on
May 22, 2008 | Dell OPTIPLEX GX110/200 PIII-866MHz 256MB...
Acer Aspire 5050-3242 Notebook Logo
113 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
