Question about Maytag PAV2300 Top Load Washer
My Maytag Insignia Top Load Washer
I am just trying to find out if you need to replace the tub when you are replacing the transmission. Thank you Nicole
    Scholar:
  • 58 Answers
Not necessarily, When replacing the transmission the important things to replace is the transmissions and the seals. If i had the model and serial i could adv you of the exact part numbers. The serial contains a special series number for parts. You can visit apdepot.com and put your complete model there to pull up parts list. But tub is not necessary unless damaged. However the seal between the transmission and tub is, which is included in the seal sets, you will see this on the website when you search lists.
Posted on May 01, 2008
WON'T AGITATE
Hello there and thank you for choosing fixya
If your Maytag top load washer is not agitating properly, you will need to check each one of the parts below until you find out which part you will need to replace to get your washer working properly again.
The free videos in these pages will show you how to do each one of the repairs the right way.
  1. How to check & replace belts
  2. How to check & replace spring & glides
  3. How to check & replace the transmission
Jun 29, 2011 | Maytag Legacy Series Top Load Washer
Sudsy water is leaking from the machine
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Legacy Series Top Load Washer model SAV515DAWW splashing
the agitator dogs are likely broken.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Maytag Legacy Series Top Load Washer
Maytag coin-op top load wont spin, motor runs, belt burns.
it not a belt, there is a $20 plastic and rubber coupling between the motor and the transmission that has broken.  It needs replacing.
Dec 25, 2008 | Maytag MAT12CS Top Load Washer
MAYTAG A-606
There are two methods used to hold the agitator in place. The first is a main bolt at the top of the agitator under the softener cup. The second is a small bolt located on the lower portion of the agitator. To access the transmission the tubs will have to be removed.
Jan 11, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Maytag Atlantis MAV6257AWW
I have a Maytag Atlantis MAV6257AWW. I need to replace the transmission. So I removed all four screws from the inner tub but I couldnt get the inner tub pull out, it's stuck.
From what I read on here, the seal nut doesn't have to be remove in order to remove the inner tub.
I tried every, I even hammer the shaft down from the inside of the tub but still no luck. Can someone help, thanks.
Jun 23, 2007 | Maytag Atlantis MAV6451 Top Load Washer
MAYTAG Wahing machine model MAV6000AWQ
I believe your machine is equipped with a "snubber plate" under the transmission. A lot of Maytag top-loaders are. This is a white teflon ring that is used as the wash tub and transmission support and assists in dampening vibrations during the spin cycles. It's located on the inside case of the machine under your transmission. When the snubber goes bad they generally start to squeak. They cannot be lubricated and must be replaced. If you try to oil them, they will eventually disintegrate. The snubber costs less than $10 to purchase. I hope this helps.
Apr 04, 2007 | Maytag MAV3855A Top Load Washer
Maytag PAV2300 Top Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
