FixYa.com
Tags:
Panasonic CX-DP880 8-Disc CD Changer
Wiring question regarding CQ-C8100u & CX-DP880
posted by ubootwo on May 01, 2008
I have installed the CQ-8100U head unit on a 05 dodge ramand now about after year I am ready to install the CX-DP880 cd changer.
Question i have is the 12v continu power supply for the cd changer. Then manual says to connect to a continuous 12v supply, which I take as the battery (this is the yellow wire from the changer). Now on the cable that hooks to the head unit this power supply wire is only 12" long from the point to connect to the head unit. How do i connect to the battery if I only have 12" of wire.
I think i am missing something, maybe this wire connects to the head unit somehow, or maybe to a hot wire off the wire harness from the ram?
Comment by ubootwo, posted on May 01, 2008
Solution is to splice the yellow 12v supply from head unit and attach yellow from changer to it. note to remove battery cable as this is a continuous hot lead.
Comment by ubootwo, posted on May 27, 2008
Now I got a new problem!, everything wired up correctly, disk tray was locked in and would not come out. I got it out but now all it says is error# 3 on dash unit.
Keep in mind was never used, brand spankin new.
Sounds like it may want to pick up disk but does not, keeps trying then shuts down.
Any tips?
Ubootwo
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Car CD Changers problems?
Car CD Changers
looking for a wired remote
i am looking to find a... Answer This...
Car CD Changers
Cd Player not working
When the ignition is turned on... Answer This...
Panasonic CX-DP880
I need to know what the pins... Answer This...
Panasonic CX-DP880 8-Disc CD...
Now I got a new problem!,... Answer This...
Repair Service
Find Car CD Changer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
