Question about Vacuums
I have an inground pool which is clear however there is sediment on the bottom ,how do i vacuum it thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=562395
Generic problem for all Vacuums
I have an in ground pool
posted by sibmrt on May 01, 2008
I have an in ground pool which is clear however
there is sediment on the bottom, how do I vacuum it
thanks
This is not a vacuum question as per the website and more of a question fro someone in the in ground pool company and they have pool cleaning equipment that works for the sediment on the bottom of the pool, my friend had one and it was called a vacuum pool snake or something like that. Sorry I could not help you with this question.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on May 01, 2008
How do I replace sqiggly hoses in my pool - I cannot find these hoses anywhere?
no doubt you need to go to a store that sells pools . I am sure they will have or know where to get it
Oct 12, 2015 | Vacuums
My polaris 280 will not start. Wheels turn ok by hand. Bag is empty, side valve of pool sucks ok, where the Polaris is now screwed into. Booster pump works and is not overheating. Do I have to have the...
Sounds like a plug in the system somewhere. Not enough water flowing through. The filter maybe clogged. Check and or replace filter(s). Also the pump needs more water for cooling. Check for partial clog.(overheating). Hope that helps.
Feb 05, 2018 | Polaris 280 InGround Swimming Pool Cleaner...
My dirt devil Rampage Robotic pool cleaner vacuum get stuck on the bottom drains
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
May 07, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
There is no suction, even though the container is empty
Your hose is clogged and needs to be cleared. You may have to remove one or both ends of the hose that connects the dirt to the container.
You might have success trying to "back vacuum" the hose. A broom handle is sure to clear the clog, however.
Thanks for posting at FixYa.com
Dec 13, 2009 | Bissell 3576 CleanView II Bagless Upright...
Cleaner is not picking up debris from pool bottom
Have you check the filter/baskets to make sure that you don't have a large piece of debris that is preventing suctions? You will also want to check each section on the vaccum systematically to make sure that there are not cracks or noticable areas of damage that would prevent the pool cleaner from working. Is is not moving at all or just not sucking properly? Can you give me more details as to what it, exactly, it is doing?
Apr 19, 2009 | Dirt Devil Rampage Robotic Pool Cleaner...
Removing the hood to clean the cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=41018&thid=498921
Posted by bfy1952 on Apr 08, 2008
How do I remove the cleaner hood the clear see thru plastic to clean under the hood?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5881-900 Vacuum. There may be 2 ways to remove the top cover. There are two screws located on the bottom and there are 2 ways that might work. The clear tube on Hoover’s sometimes will swivel and that is the way to bet the clear tube unclogged, or once you remove the 2 – 4 screws on the bottom the top should lift right off, and then you can serviced your vacuum cleaner. If you have questions you can always contact your local vacuum cleaner dealer in your area or call tech support @ the Hoover @ the factory and ask for tech support.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Hoover F5881-900 Vacuum
Vacuums Logo
126 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
