Question about Dishwashers
It not cleaning good - Dishwashers
    Scholar:
  • 58 Answers
First detergents, make sure that its not expired. 2) some dishwashers do better with liquid or powder, so try each one, brands can vary also.
If hard water use more detergent soft less.
If only not cleaning on top rack you have a water pressure issue.
Also ensure you are properly putting the dishes on the rack, incorrect dishes restrict flow, pressure, and cleaning action.
Posted on May 01, 2008
My Dodge caravan will not start when cold.
the entire system must be in good working condition for a vehicle to start in cold weather. Strong battery, clean cable connections at the battery, good starter, clean/gapped plugs, clean injectors, good plug wires, clean fuel filter, clean air filer, and good gas. If a vehicle sits with a partially filled tank for long periods, condensation can form in the tank and freeze. Use gas line antiifreeze in the winter.
Mar 02, 2015 | Dodge Caravan Cars & Trucks
PP2075 starts with the muffler off but not with it installed. Muffler is clean - screen is clean - center facing the right way. Good fuel etc....
mufflers can be clean and still not work properly. After removing muffler and unit runs then change your muffler and clean your exhaust port while doing so
Sep 18, 2014 | Garden
601 ford starting problems
Many more details are important to help you solve your problem.
Things to check and report:
What are the conditions when it wont start? (cold, wet, hot, all the time)
Is your battery charged?
Are the battery connections good?
Does it turn over or make any noise when you turn the key?
(if it clicks, try bypassing the solenoid to crank it, or replacing it)
If it cranks over well but doesn't fire check:
Is your fuel fresh/clean?
Is there good fuel in the actual carb?
Is the fuel bowl clean and have no contaminants in it? (any contaminants at all probably mean a good carb cleaning is needed)
If fuel is all good, Do you have spark?
If no spark check:
Are your points clean and properly gapped?
Is your distributor cap and rotor clean, dry, uncracked and in good condition inside?
Are you plug wires and plugs in good condition, clean, flexible, etc?
If all those are good, check for spark from your coil
Any and all of these affect your tractors ability to start. More details will help isolate and repair your issue.
Aug 03, 2013 | Garden
I've tried to clean the VCR heads with a cleaning tape , but I still only get snow when I play a tape, the audio is good.
The best solution is to take the top cover off the video and give it a really good clean. Get some Servisol Video 40 to spray on. Clean every surface the tape touches. You can use a cotton bud to get into tricky places. It will take longer to clean if the video is in the home of someone who smokes. Cleaning tapes never do a good job, if the video hasn't been cleaned before.
Jul 18, 2011 | Panasonic PV-V4022 VHS VCR
Van does not want to start. Replaced battery, and it worked for a few days. Now it won't start, though it sounds like it is going to.
There could be a whole load of issues here.
1) make sure the battery has good charge.
2) check the HT, plugs, coil, all good and clean connections.
3) check the fly wheel sensor is good and clean.
4) check the water temperature sensor is good and clean.
5) check the fuel filter is clean.
6) check the fuel pumps works.
7) check the cam belt hasn't broken.
Feb 17, 2011 | 2002 Chrysler Town & Country
Computer hang when print command to tally
Do the following
(1)Scan and clean all the viruses in your computer with a good Virus Cleaning software
(2) Make sure your registry is clean with a good registry cleaning software
(3)Reinstall your printer driver
If this does not work you might need to repair your Windows. Just insert your bootable Windows CD/DVD and follow the instructions.
Good Luck!
Nov 12, 2010 | Computers & Internet
I just got a good answer for this question below but i did clean the carbon ring at the top of the cylinder and carbon on the top of one piston...is that bad?? good morning! i have a 01 cherokee with a 4.0...
That carbon build up is bad!Carbon is what a diamond is made from and pieces of it breaking off will decrease the life of your engine.Also the carbon will heat up and cause premature detonation in the combustion chamber.Just wait till he leaves the garage and clean it off before reassembly.
Take care!
Jan 17, 2010 | 2001 Jeep Cherokee
Our bosch shu9902uc dosnt clean the dishes,ive tryed to clean out the drains,blew compressed air thru the drain line,cleaned out the sprayers,still it dosnt clean food off the dishes. water plenty hot and...
make sure you clean the sprayers out real good,if theres debris on the end nozzles they dont spin around too good,also pull out the little service plug that protects debris from getting in the impeller.
i found a little chunk of wood in there! im still not sure how wood ended up in the dishwasher!
Jan 04, 2010 | Bosch SHU9922UC Built-in Dishwasher
Welds good then spits after 1/2 in.
make sure your surfaces you are welding to are nice and clean and free of rust, make sure you have a good clean ground also
Mar 30, 2009 | Welding Tools
Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Jan 19, 2009 | Kenmore Dryers
Dishwashers Logo
305 people viewed this question
Top Dishwashers Experts
