Question about Lexmark P4350 All-In-One InkJet Printer
My lexmark printer p4350
I cannot get it to print a full page , there is a ghost image of printing at the side
    Genius:
  • 3,422 Answers
You can try to do a hard reset first and then reinstalling your drivers.To do a hard reset just unplug all the cords from back of your printer for 30min and then plug it back in and after that reinstall the drivers.If you still face the problem then it can be a damaged fuser.Do you see any re-printed images of the actual text or black blurry images?If yes then it is a damaged fuser.
You will then have to get it repaired to fix it up..
Goodluck,
Please don't forget to rate the solution
Posted on May 01, 2008
    Guru:
  • 147 Answers
Fellow FixYa colleague IBG wrote this awhile back and I quote:
"I'd strongly recommend that you consider doing the following if your printer is unhappy:
Unplug from your computer.
Turn off printer.
remove old drivers through control panel/printers
Go here for an updated set of printer drivers. Most of the CD's shipped with printers are obsolete within a month or two of their ship date.
Reverse sequence above.
Try it you'll like it."
Please let me know if this helps. Thanks and have a great day!
    President:
  • 2,712 Answers
Hello wapeta,
It looks like you may need to reinstall the printer driver.
HERE is a link to download the driver.
You may want to do a clean install to avoid conflict with other software during installation.
Clean boot/install procedure:
1. Unplug the printer from the computer. Later you will be prompted by the software to plug in the printer; do so at that time only.
2. Open the Windows Control Panel.
3. Open the Add / Remove Programs window.
4. Locate the listing for the old driver and remove it. When prompted to remove the printer drivers files, click Yes.
The following is the procedure for a 'clean boot'. I am assuming that you have XP. If you have a different OS, just let me know and I will send you the appropriate procedure to boot clean in that OS.
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
3. Uncheck Process SYSTEM.INI file
4. Uncheck Process WIN.INI file
5. Uncheck Load Startup Items
6. Click on the Services tab
7. At the bottom, check Hide All Microsoft Services
8. Uncheck all boxes in the window or click the button labeled Disable All
6. Click OK
7. Click Restart
After restarting, reinstall the downloaded software. Next , do the following:
1. Click Start --> Run --> Type MSCONFIG--> Click OK
2. Replace checkmarks in the items that you previously removed them from.
3. On the General tab, choose Normal Startup
4. Click OK
5. Click YES, when asked to restart your computer
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Lexmark p4350
Try to align the cartridges using the Lexmark software installed on your computer to fix the problem. Please follow the steps below:1. On your computer, go to Start menu.2. Go to Programs.3. Go to Lexmark P4300 Series folder.4. Select Lexmark Solution Center.5. Select Align to fix blurry edges. Your printer will then print a page that will align your cartridges.
Try to print your document again to verify that the problem is fixed.
Dec 27, 2011 | Lexmark P4350 All-In-One InkJet Printer
Since conecting my Lexmark P4350 to a different pc it is sometimes only printing half a page and sometimes the print is smudged. can you suggest anything.
Make sure that the printer driver is properly installed. Please visit the Lexmark website to download and install the Lexmark P4350 Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. After the install process is complete, try to print again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark P4350 All-In-One InkJet Printer
May I connect this to wireless?
You can but to a print server router cause you would only be able to print wireless.
http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-P4350/catId=cat10004-category&prodId=2505-product;jsessionid=E4E9EDA3E75194137F2AD0E576DC6B58.node1
Talks about it on this page for the optional ports.
Jan 06, 2010 | Lexmark P4350 All-In-One InkJet Printer
Only one page is printing out of many pages
On your print preview, or print settings from your document or page, Make sure the settings say print all or print page 9 or 9 or whatever you are using
Aug 06, 2009 | Lexmark P4350 All-In-One InkJet Printer
My Lexmark P4350 printer is not scanning images to my computer?
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 4300 Series, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
May 11, 2009 | Lexmark P4350 All-In-One InkJet Printer
Printing
No solution was not solved, but would like to know how much a the hard disk will cost since.
Dec 27, 2008 | Lexmark P4350 All-In-One InkJet Printer
pls format your pc then checked.
Jun 11, 2008 | Lexmark P4350 All-In-One InkJet Printer
Have no disc to reinstall model p4350
Drivers for the Lexmark P4350 are available at the bottom of this page.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 02, 2008 | Lexmark Office Equipment & Supplies
Delay between prints
sounds like a lack of printer memory allocation to me..
Feb 21, 2008 | Lexmark P4350 All-In-One InkJet Printer
Not printing or scanning at high resolution
If the Lexmark software doesn't work you could just try using other software. Picasa http://picasa.google.com is a free photo management software and does a great job of printing photos. You can scan from an application like Word or using the "Get Picture using Scanner Wizard" menu that shows up when you right click the Scanner in My Computer in Windows.
Sep 29, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
