Need information on how to set it up
Fax is in TDA Status
This is the direct link for the pdf version of the manual:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_2820_2920_MFC_7220_7225N_EN_1344.PDF
and here is the quick setup guide:
http://www.brother-usa.com/ModelDocuments/Consumer/Quick%20Setup%20Guide/QSG_IntelliFax_2820_2920_EN_1244.PDF
SOURCE: Fax Confirmations
1) Menu/set
2) 2
3) 4
4) 1
5) Press + or - "ON" or "ON+ IMAGE" to have confirmation with a preview image of the first oage you sent
6) Menu/Set
I have a phone line and fax line running into my home. They are on the same line. When I have my fax machine plugged in, I cant get my phone calls on the fax only setting. If I set it to fax/tel I do not get either. Is there some set up function that I have to do for my fax machine to route the calls correctly?
on my fax machine when the phone rings and my home phone answering machine picks up the fax machine will keep ringing i need to know all the setting so i can reset it then it takes an hour to recieve a fax HELP
how do i get it conect with the computer
