Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Refrigerator stopped working, freezer works fine
Our 2 year our Jenn-air French Door fridge suddenly stopped cooling in the upper (refrigerator) compartment. The bottom freezer compartment works fine (-20F). We have tried unplugging and repluggin the power cord. No change. We hear a hum inside the fridge, but do not think the compressor is running, since the whole unit is much too quiet and is not vibrating at all. Lights are on inside the Fridge. We have also tried running the thermostat up and down to min and max settings? Any other simple suggestions or is it repairman time? The freezer works, buts the refrigerator does not. This occurred after the power was shut off for a few hours.
  • Anonymous Jul 31, 2008
    my kenmore is freezing but the refrigerator is not cooling like it should. The motor is kicking in and out. What do u think it could be?
I turned off the refrigerator and left the freezer door open so the coils and the vents could thaw out. The cold air was not getting to the refrigerator section because of ice blocking the vents.
Posted on May 06, 2008
2 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: refrigerator stopped working, freezer works fine
Sounds like the evap fan is not running. The fan takes cold air from the freezer to cool the refer compartment. If the freezer is cold the compressor is running. Generally the freezer will stay cold since the cooling coils are there but it must have the fan working to get the air up to the refer area. Pull everything out the freezer and take the back panel off to view the coils and fan, etc. It's a simple easy job to change the fan. If you find the coils are a total block of ice then it's another problem... the defrost cycle isn't working. Sooo... see if the fan is running in the freezer compartment first. See http://www.partselect.com/Schematics/Maytag/AA43-57.gif for fan location, item 18 is the fan motor. Let us know what you find out.
Posted on Jan 02, 2007
Jenn-air gasket is hot
The refrigerator portion is fed cold air from freezer section to cool it. Check for the freezer fan and/or the damper mechanism that directs air into fridge compartment for proper operation.
Sep 03, 2017 | Jenn-Air Refrigerators
Freezer works fine, top not cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Jenn-Air JFC2070KRS Bottom Freezer French...
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 15, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Same as below...
HELLO,
Is this fridge more than a year, if it is, then I would kindly suggest, :) to have a new coolant installed, and then run the fridge some time, it should kick back to normal...:)
Sep 09, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Jan 02, 2007 | Jenn-Air JFC2089HE French Door...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
707 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
