FixYa.com
Tags:
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Kitchenaid superba ice freezes in the bin (by 2 users)
posted by tpagirl on May 01, 2008
i have to empty out the ice bin every couple weeks bcuz the ice in it starts to freeze solid. also freezing up at the bottom of the bin where it is to be dispensed to the door.
Comment by tpagirl, posted on May 01, 2008
ok thanks, i'll give that a try. it was set on the arrow in the middle, so i moved it to colder setting.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by rufie, posted on May 08, 2008
The dispensor door for icemaker doesn't close all the way. Causing the ice to freeze solid above the dispensor.
Solution #1
Not Rated (0)
Merkader
Rank:Master Master
Rating: 80%, 13 votes
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Refrigerators problems?
KitchenAid Superba Architect KSCS25INSS Side...
diagnostic codes for...
how do you input to get a code Answer This...
water leaking at bootom of...
water is leaking from bottom of... Answer This...
Kitchenaid Fridge not working
Model KSCS25INSS00, bought... Answer This...
overactive ice maker
the wire that triggers the ice... Answer This...
WATER FILTER LEAKS
water leaks from the water... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
