Question about Canon FAXPHONE L170 Plain Paper Laser
Faxphone L120 Hi, anybody know how to get access to the scanner window, so we can see if its dirty oe scratched? We can't seem to figure out how to get there. thanks, Robert
  • 2,016 Answers
According to the Basic Guide for the L120 (page 8-4), you lift the paper stack cover and pull it out completely. Once it is out, there is a small 'handle' at the top center of the opening. Pull down on this to lower the scanning platform into the document delivery area. Reverse this procedure when complete.
Posted on May 01, 2008
Good day. i am using the ssc service utility to reset the waste inkpad counter for my epson l120 but error does always appear how could i fix this? please give me an exact solution to this? thanx..
You can't use SSC service to reset this printer EPROM.
The best solution to reset this printer by using Epson Adjustment program for L120 which you can get it from the other sites(for free). The other program with the same capability you can find it here
Hope this will answer your question.
model_=_l120__port_=_auto_selection__adjprog_ver_2017-08-25_12-49-37-gonwqssj54xei2lmigmvvzjk-4-0.png
Epson L120 Free Resetter
May 09, 2017 | Epson Computers & Internet
The heads on my fax machine need cleaning how do i do it
Your fax machine (L120) use dry toner and not ink cartridges, so it doesn't have printhead. If the copies are dirty or bad but received faxes and printed documents are OK, then You have to clean the scanner unit (it's above the plain paper storage and can be opened with small handle).
Hope this was helpful
Aug 28, 2015 | Canon i-SENSYS FAX-L120 Laser Fax Machine...
I need to make the scanner available on the network, the printer is networked OK but can't seem to figure it out. Can you help
Need to know what printer and how it's hooked up.
For instance, if it's an all in one printer (epson or HP etc) and it's hooked up USB to one computer and shared across the network, you can't share the scan capability across the network.
What yu'd have to do is scan to the computer that it's hooked up to, placing the scans into a folder that is shared across the network so anybody can access it.
If it's a network capable scanner with it's own Ethernet connection, then the process can be vastly different, but the scan function should be sharable across the network.
Jul 21, 2011 | Office Equipment & Supplies
Hi, i have this code error E000020 with my canon ir 2525 photocopier.i dont know what to do.please help me.thanks
1*Check the yellow drum unit, laser shutter or the plastic actuator on the right side of the front door. good luck.
2*Dirty Drum patch sensor OR the drum has reached 100% of it's life.
iRC3100 drums NEVER go past 100%...once they reach that magic figure in the counters then it's time for a drum replacement.
If you know how to access service mode then check under:
COPIER>DENS>P-SENS-P and make sure that the figure is around the 500 mark...if it's below say,250 then that indicates that the drum patch sensor is having trouble reading correctly and may either need cleaning or a new drum unit.
Mar 15, 2011 | Computers & Internet
I have 5 scanners and 3 access points in my warehouse and the scanners only stay connected when I only have one access point turned on and the scanners set to connect to that access point (Mandatory), then...
Hi, that is happening because your 3 APs have the same fixed IP address. you have to change the ip address on 2 APs, right now it seems to be that your 3 APs have the same fixed IP address, for example in my warehouse, for AP #1 is 10.20.40.30, for AP #2 is 10.20.40.31 and for AP# is 10.20.40.32 hope it helps!!
Dec 06, 2010 | Symbol MC9090 Barcode Scanner
I have a faxphone l120 every time i try to send a fax is say tx cancelled and goes to check scan platform i need instructions that are dumby proof
Hey! If you take out the cover thats covering the recieving paper,Look in there and u will see a black lever with a green sticker on it!You should see a thin glass covering a whitish area,Push that up untill you hear the clicking sound! Enjoy!
Sep 09, 2010 | Canon L120 Fax Laser Printer
Acerscan 620U upgrade to Vista
Go to the Acer website and enter your particular model and you can download the official drivers from there....
Sep 05, 2008 | Acer ScanPrisa 640U Flatbed Scanner
Check scan platform
Two things cause this, a dirty scanner or after the user cleaned the scanner it was reassembled incorrectly Directions are in chapter 8-4 of the “Basic Guide”
Apr 02, 2008 | Canon L120 Fax Laser Printer
Canon FAXPHONE L170 Plain Paper Laser Logo
73 people viewed this question
old marine
old marine
