Bushnell Golfhttps://www.bushnellgolf.com > support
In the Bushnell Golf App, Select Your Wingman Device and Settings. Scroll down and confirm the Auto Hole Advance is On under the Play Golf Speak Settings. Also ...
This replaces the Bushnell Neo Ion 1 watch, and adds Bluetooth technology for wireless course updates, a reversible band, and compatibility with the Bushnell app. So relatively minor updates on the surface. NOTE: As of November 2022, it appears as though this watch is no longer supported by the Bushnell app.
Nov 1, 2022
Change the setting on your Program dial, try Manual and you should be able to access it. Under certain settings, it will not let you access the advance settings, because you are in a Program mode, like Landscape, Speed, Night, or even Program and Auto.
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
I suspect you have a timer motor problem. My experience has been in most cases you cannot buy just the timer moter, you need to purchase the entire timer....at costly expense. If you can get your ear near the timer while running, first listen to hear the motor. Usually when the motor is going to quit, it becomes fairly noisy. In any case, the timer should advance,
hope this helps- sounds like someone replaced your timing belt and when they replaced it, they were off by one a tooth or peg on the belt- buy a Haynes manual from Advance Auto parts or go to Advance Auto Parts and look for an OPENED 2003 Ford Focus Haynes. Read the part about installation of timing belts. You DO NOT have to remove the timing belt, just make certain it is correctly lined up with the proper marks. If you are a decent mechanic, you can do this yourself. Unlike cars in the 70's you cannot adjust the timing on today's Vehicles
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
It sounds like a timer problem since it happens during timed also. Some dryers don't have an actual moisture sensor for auto dry. They work by knowing that as long as the clothes are wet the temp won't go past a certain point. As the clothes dry it trips a thermostat that lets the timer advance. Until this is fixed DON"T trust the timer to shut off the dryer. Sometimes it won't or could leave the dryer running for hours. This has nothing whatsoever to do with fuses. There are no fuses in a dryer. Just high limit thermostats and other devices that will shut off the heat but usually not the motor.
