Question about Sharp AR-160 Copier
AR-160 I cleaned the charger and now I get an L4 message. Anything I can do- service is sooo expensive.
  • 29 Answers
Type this c-interup-0-c the machine will shutdown and type 14 and press start key.
Posted on May 02, 2008
  • wilfredo benito May 02, 2008
    type this c-interup-0-interup the machine will shutdown and type 14 and press start key.it will reset the error code if not,replace the main motor.
    type this c-interup-0-interup the machine will shutdown and type 14 and press start key.it will reset the error code. if not? replace the main motor.
How to fix Sharp Copier AR-5731 Error code
good day, my Sharp AR 5731 showing the message Call for Service . Code : H4-00 can you help me to fixed my problem. thanks and God Bless
Mar 11, 2013 | Sharp AR-BC260 Color Copier
SHARP AR5316E error L4-11
L4-11 shift motor lock to clear press #/p - asterisk(*) - clear(C) - asterisk(*) (14) on the 10 key pad start or execute machine should reset or you may have to hit CA key if problem returns call service.
Aug 18, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error code L4 30
L4 error code mean your copier motor fail problem.
Please press # Interrupt C interrupt press 16 press start key or print key.If are not fix this problem please check motor fuse or any kind of gear was broken.
Dec 16, 2009 | Sharp AR-M455N Copier
CODE ERREUR L4 DANS UNE PHOTOCOPIEUR SHARP 5316
L4 mean this copier main motor is not move or run.
First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
Dec 02, 2009 | Sharp AR-5320 Black and White Copier
Sharp ar -m351 Error codes L4-30
sharp printer mx-m450n error code l4-02
Nov 24, 2009 | Sharp AR-M450N Copier
Sharp ARM-160 I have an error code L4-11.....any ideas?? Thanks
Please verify the continuty of the LAZER UNITSand the POLLYGON MOTER is.The problem in pollygon moter
Nov 02, 2009 | Sharp AR-M160 Laser Printer
Cant recieve text messages on lg neon
i hate my lg neon sooo much    its been 2 months and it doesnt work and it fell apart and i havnt told anyone    i had to snap it to gether but it is so fragille and wobballly
Sep 20, 2009 | LG Neon GT365 Cell Phone
SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Jan 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Sharp copier m550n
L4-03 is a lock of the fusing motor. It's likely you need to have the fuser rebuilt. You can try resetting the error by turning off the main power switch (located behind the front door under a little plastic cover) and back on. It's likely the error will come back. There's a cleaning screen on the lower fuser roller which gets gummed up with toner and sticks to the lower fuser roller causing it to seize and the motor not to be able to turn causing the L4-03.
Oct 06, 2008 | Sharp AR-M550N Copier
Sharp AR-160 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
