Question about Panasonic DMR-HS2 DVD Recorder
DVD Disc Drive
Continually getting this this is not recordable. Using DVD-R Fujifilm brand. hey have worked before.
So farit seems that the laser lense or the laser coil is bad. I found my lense chipped. One site indicated this is because of the use of "bad" DISCs that cause the laser diode to overload because of repeated attempts to read the bad disk. The coil and/or diod get hot and burn. I don't know how my lense got chipped!?
Posted on Sep 04, 2008
  • davesmithone Sep 04, 2008
    Where can I get a replacement DVD burner unit?
Sony dvd handycam
it seems like your videos are locked
Feb 06, 2012 | Sony Handycam DCR-DVD92 DVD Camcorder
Dvd not recording
are you using the same brand of DVDs you recorded last year (and the brands that the manual suggest)...and if you are using dvd-rw on the pc and dvd recorder you will also get this message..(just format and record)...
I also find that Imation DVD works (its not listed in my manual) but when Im not using Maxell or Panasonic it works like a charm on both PC / DVD recorder
May 07, 2010 | Sylvania DVL500B Multi-disc DVD Player
Funai VCR/DVD recorder DVR 2737. My -R discs record ok but during finalising I get disc error - cannot record on this disc Error code E22. Can you help?
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Oct 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Error code E 4 54040990
I, too, was having this same problem, and as the last respondent suggested, try cleaning the lens. There are a number of kits out there (I got a Philips for about $12 at Walmart) and problem fixed. Works like new. I plan on running the disc on all my dvd players and PCs. Good luck!
May 27, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Will not read blank media so that I can record.
Ok, Firstly it sounds like you have reasonable knowledge on what you're doing.
But just to clarify a few things.
1.You say you have tried a couple of different brands of disc.Unless they are of good quality
or compatible with your machine they may not work properly.Try TDK or Verbatim for example.
Also make sure they are DVD-R or DVD-RW.
2.If no blank discs are successful,then you may need to clean the laser lens thoroughly.
I know you said you cleaned the lens,but was this with a lens cleaner disc?
If so it will only remove dust not built up grime from other sources such as smoke from cigarettes.
This would entail taking the cover off the unit and cleaning the laser lens directly with a
cotton bud dipped in cleaning fluid.If you are not confident in doing this,then you
would need to get someone qualified to do so!
I have gotten many DVD Players and DVD Recorders working again doing this.
May 20, 2009 | Samsung DVD-R130 DVD Recorder
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
Cannot get DVD recorder DVD 3470H to download from hard drive to a disc. The machine is about a year old and I'm using recordable DVD-R When I try to record onto the disc I get a screen which says the...
Hi Guys,
Thanks for the response.
I've solved the problem.
I was trying to download a programme that was too big from the hard drive to the disc.Once I inserted a divide in the progeamme everything worked Ok,
Dec 16, 2008 | Televison & Video
Burning DVD
try DVD-R Dics the manual says not compatable with +R.
Jan 13, 2008 | JVC Everio GZ-MG130 Camcorder
Unknown disc error message
Aug 27, 2007 | Televison & Video
Panasonic DMR-HS2 DVD Recorder Logo
225 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
