Question about Whirlpool Kitchen Ranges
I have a stove pt# 9752777 Rev - B, one on and off switch get burnt. i like to order on switch, please let me know the price aswell. tc
Panasonic TC-29T400W Tv remote model number
hi
ckeck this out hope this will help
http://www.ebay.com/itm/NEW-Panasonic-TV-Remote-N2QAYB000820-TC-50A400U-TC-P50X60-TC-P42X60-TC-32A400U-/201237662124?pt=US_Remote_Controls&hash=item2edab309ac
Dec 17, 2014 | Televison & Video
Ariston stove wiring cx 67s p6 x ng
When you replaced the burnt out selector did you notice any other damage? The selector switch may be connected to the energy input control. Most circuits have some sort of control, allowing only the right amount of energy to be put in. If this got damaged, the fuse would be inconsistent.
Elisa Jed ' http://www.atlasappliances.com
Jun 22, 2014 | Stoves 720EF Electric Double Oven
The plastic panel where you turn washer on , I pushed too hard and it broke but I don't know what its called to replace it? After it cracked machine won't turn on. Need your help please.
Plastic control panel. It could also be electrical panel. You can order part from the Internet. Just use "appliance parts" Then pick one of many appliance part vendors. They will have sub-catorgies; such as, washer, dryer, stoves, etc.etc.
Well, Flower Lady check your local dealership for pricing. This will give a good estimation to buy parts from the vendor on the internet. I have saved money buy from internet but you need know your prices on parts. So, check the prices before buying and find the vendor that will ship free. GB...stewbison
Aug 21, 2011 | GE Profile WPRE6100G Top Load Washer
I have a panasonic pt-50lc14-k and my light bulb burnt out ..im wondering where do i buy the bulb to replace it and how much will it be?
Mats Electronics has Lamps for $89.00 1-800-628-1118
Encompass Parts Distribution will list Parts /Prices visit their website 1-800-638-3328
Dec 30, 2010 | Panasonic PT-50LC14 50" Rear Projection...
MAIN OVEN FAN STOPPED WORKING
Firstly switch off the stove isolator(switch)
1:I would suggest removing the back panel and checking the wires to the motor to see if any terminals have broken/fallen off(on the Zanussi ovens you should be able to see these easily).Also check that the armature can spin freely.
2:If OK, Switch isolator and stove back on and check for voltage (230v) to these terminals.
3:If No 1&2 solutions have not solved your problem please come back to me.
Hope I have resolved you question, but please leave positive feedback if so , as it still takes time to answer questions and it would just be nice to know if I have helped.
Aug 12, 2009 | Zanussi ZDF490 Electric Double Oven
Indicators lights come on
First thing to check is to put your hand over the burner when the indicator comes on and see if the burner is actually hot! DO NOT actually touch the burner! The smell of your own burning flesh is not so pleasant, and could cause you to pass out with your hand still on the burner or something like that, so be careful. More than likely, the problem is with the burner switch, but could be with anything between that and the actual element.
What did they quote you $350 to repair???? Was that parts and labor, or just parts? Sounds very high. If, however, you have one of the older stoves with a ceramic top that had the element in the top, you have to replace the whole thing to fix one burner, not very smart, economically. Newer stoves use seperate elements beneath the glass top, and so are much less expensive to repair.
Go to the Sears.com website, and click on the parts link (it's in a line of grey typed links, relatively small font, a couple of inches below the top of the website home page, and toward the right side.) Type in your model number on the right side of the parts page where it says to, and it will come up with a parts breakdown that has a list of the parts and their prices. If they never sold your model, you might have to come up with a similar model that they did sell in order to get parts listings that would work.
That will at least give you an idea of prices. You should also look at the switch for that burner.  If the burner won't run on either size setting, I'd suspect the switch or that the power is not getting to that switch.
Remember, you are working with 220 VOLTS here, and be very careful. But if you can handle a voltmeter, you can determine if power is getting to the switch, and getting out of the switch, and if it is getting to the element. You can buy a DVM at Radio Shack or Sears, or just about anywhere else, these days. Elenco is a company that makes decent ones very cheaply, and you can buy them online. Or you might have a friend or relative who has one at home, and knows how to use it around 220 volt circuits....
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Burnt stove element
It is if its installed like the other one.Generally they are just shaped differently.If the wires are connected safely you should be ok.
Please rate This !!!
Jul 30, 2008 | GE Profile Harmony DPGT750EC Electric...
Kitchen Ranges Logo
65 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
