That is a thermistor error code. there are several causes for this. the thermistors are dirty, the upper fixing roller is damaged or it might have paper wrapped around it, or the connecter on the back of the fixing frame has a hair line crack in it. now you can clear this code if you you think there isn't anything wrong with the afore mentioned items.
you have to get into service mode. first you will have to shut the copier off at the main power switch and turn it back on once the error code pops up on the screen you will need to get into service mode.
you hit the
additional funtions button
then the 2+8 at the same time
then additional funtions button again
once in service mode you will need to follow the following steps
hit the copier tab
then the funtions tab middle of screen across the top
then hit the clear tab
then the err tab and hit the ok button to clear error
now you only have like 30 seconds give or take to get into service mode and to clear the error code before the machine shuts down if you don't get in fast enough dont worry shut the copier off and turn it back on and keep trying till you get in and clear it. trust me it took me several tries my first time i realized this myself.
