Question about ParkerVision SIGNALMAX WR1500 (884181000031) Router
My new alarm system / wireless router
I am getting a house alarm installed and they said I need a hard wired router. Right now I have a parkervision wireless one. Does parkervision make hard wired routers and if so how do I get one? Also, if I get one does that mean I have to hook my lap top up to it when I use the comper?
  • 156 Answers
What type of Alarm system? If that pakervision has network ports on the back there is no reason they couldn't run a cable to it and setup the security for you. I've never heard an alarm company tell a consumer "No you can't have wireless in your house" I'd need to know the model # of that parkervision because this doesn't make sense to me. If that parkervision doesn't have any network ports on it... yea go out and buy a wireless router that has ports on it.
Posted on May 02, 2008
What is the difference between wireless alarm systems and hard wired alarm systems?
The difference is wireless means exactly that no wires but I found that woth wireless systems unless u pay a fortune on an un hackable (well supposed to be ) and a hard wired system is hardwired to ur home or just plug into ur standard wall socket I found that these systems are alot more reliable an less likely to be hacked by wirelss devices such as blutooth etc
Oct 15, 2014 | Home Security
What are the different types of home alarm systems?
There are two types of home alarm systems, the wireless home alarm system and the hard wired home alarm system. Wireless home alarm systems are the most common these days with many of them having a simple do it yourself installation. Hard wired home alarm systems are still around and still used, however. Wireless home alarm systems are much simpler to install and much easier to maintain. (www.prweb.com)
May 07, 2013 | Home Security
I have two ParkerVision WR1500 4-port Wireless DSL/Cable Routers. The first one I have connected my Ethernet Cable from my modem to the WAN port. This is where I get my Internet Signal. My understanding...
You won't get internet connection that way because there is no connection between the first parkervision and the 2nd one.
Best way is use only one parkervision router. Connect WAN port to modem for internet, 1st lan port connect to your pc and 2nd lan port connect to 2nd pc in other room. 2nd way is, use only one parkervision. Connect WAN port to modem for internet, 1st lan port connect to your pc, setup wireless SSID and connect your 2nd pc to this router for internet wirelessly. Assuming your 2nd pc has wireless capability.
Apr 13, 2011 | ParkerVision SIGNALMAX WR1500...
I am a windows running computer connected to a Parkervision signalmax wr1500 router... I have internet access but my laptop (mac) cannot find the network that was previously accessible. What did I do...
If your mac is trying to connect wirelessly? If so, did you secure your wireless by disabling the broadcasting of the SSID?
If you have disabled SSID broadcasting (which is a good security measure), you will probably need to manually add the wireless network and key to get this to work.
Hope this helped! :)
Oct 16, 2010 | ParkerVision SIGNALMAX WR1500...
Parkervison wr3000
You can enter the routers setup pages by entering the default IPaddress into your browser (192.168.150.1). The default passwordis 1234. You must get into setup and insure the the wirelessradio is enabled before any of your clients can attach to the router.
What type of wireless devices are you trying to attach to therouter? If one is a notebook PC is the router visible as anavailable network?
Oct 25, 2009 | ParkerVision WR3000 Router (WR3000PARKER)
LOST SOFTWARE TO PARKERVISION WR 1500 --- PLEASE HELP ! ! !
You do not need to have a disk for the router. The router has firmware built into the router. Make sure you have your lan into the 1 port and type in your browser 192.168.150.1 and it should take you to a screen to log in. The default is 1234 for the user and password.
You should be able to use the wizard inside of the router after you log in. Hope this helps!
Nov 20, 2008 | ParkerVision SIGNALMAX WR1500...
ParkerVision Signalmax WR1500
from the original docs:
Reset Button
The WR1500 Wireless Router reset button is built into the rear panel. Use this button to restore the factory default password to 1234; IP address to 192.168.1.1, subnet mask to 255.255.255.0 and DHCP sever enabled with a pool of 8 IP addresses starting at 192.168.1.33.
note my unit resets to ip 192.168.150.1
Sep 29, 2008 | ParkerVision SIGNALMAX WR1500...
Real simple question...about turning off the "Wireless LAN" option on my WR1500
it should, well to make sure that it isn't there's an LED indicator on your router that say's wireless or WLAN, since you've unchecked the feature on the router that say's Enable WLAN it should only work as a wired router and would not transmit or broacast any signal.
hope this answers your question regarding the router's wireless trasnmission.
Aug 06, 2008 | ParkerVision SIGNALMAX WR1500...
Paker vision router
did they tell you at parkervision that the IP address waws printed wrong in the installation manual/disc ?
try replacing the last set wiht 151 and see if you can see the router through the computer, then set up your router and network. Mine worked just fine after this little misprint
Mar 27, 2008 | ParkerVision Signal Max USB1500 1 Mile USB...
ParkerVision SIGNALMAX WR1500 (884181000031) Router Logo
60 people viewed this question
Top ParkerVision Computers & Internet Experts
Aris C.
Aris C.
Folusho Adeyanju
Folusho Adeyanju
Larry Maranto
Are you a ParkerVision Computer and Internet Expert? Answer questions, earn points and help others
