1990 Mitsubishi Mighty Max Logo
Posted on Aug 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking to buy a used 90' Mitsubishi Mighty Max. My question is it worth buying if the main computer chip is out and is this a simple fix?
Michael Khait
Level 2:
New Friend:
  • Expert 145 Answers
  • Posted on Aug 16, 2010
Michael Khait
Expert
Level 2:
New Friend:
Answers
145
Questions
0
Helped
49495
Points
326
New ecm is exactly 199.99 online www.ecmdepot.com
  • jesez22 Aug 16, 2010
    Is this a fix that I can do myself or will i be abused by the over charged shops in my town
What years are the windshield for a 1990 Mitsubishi mighty max interchangeable?
Mitsubishi Mighty Max Parts & Accessories - JCWhitney
www.jcwhitney.com > Mitsubishi
Below you'll find a wide variety of Mitsubishi Mighty Max parts and accessories. Enter the year of your Mitsubishi Mighty Max to get a more customized product ...
Mitsubishi Mighty Max Cars and Parts ' eBay
www.ebay.com > eBay Motors > Cars & Trucks > Mitsubishi
eBayResearch Mitsubishi Mighty Max popular models, prices, photos and read reviews. ...Tell us what you thinkthis item - opens in a new window or tab. Mitsubishi Mighty Max. Share: Mitsubishi Mighty Max Model Years ... Mitsubishi Mighty Max · 1990 Mitsubishi Mighty Max · 1989 Mitsubishi Mighty Max · 1988 Mitsubishi Mighty ...
Mitsubishi Mighty MAX Parts, Mitsubishi Mighty MAX ...
www.carparts.com > Mitsubishi
Through the years, your vehicle's components will succumb to wear and tear, ... In addition to replacement Mitsubishi Mighty Max parts, you may also want to buy ...
What is the torque for installing the crankshaft for the 2.4 mitymax motor?
Mitsubishi Mighty Max crankshaft bolt Questions & Answers ...
www.fixya.com > ... > crankshaft bolt > Cars & Trucks > Mitsubishi
Mitsubishi Mighty Max cars & trucks crankshaft bolt questions and answers. ...Torque specs for mighty max The head torque specs for 1991 mitsubishi mighty max 2.4 I ... 1989 mitsubishi 2.0 motor crankshaft was turned while timeing belt was off. ...how to install a clutch kit on my 1994 mitsubishi mighty max Disconnect the .
1helpful
CAN I PUT A/C ON MY 89 MITSUBISHI MIGHTY MAX CAUSE IT DONT HAVE NONE AT ALL?IF SO HOW MUCH AND WHAT DO I NEED TO BUY.
Short answer - Yes......BUT......
It will be TERRIBLY, HUMUNGOUSLY, ASTRONIMICALLY EXPENSIVE !!!
When buying this vehicle brand new, you could request 'factory' aircon option for around $1,000 - $2,000.
To attempt to install all the components 'aftermarket' would be several thousand dollars.
You would require additional aircon radiator/condensor, all piping (engine bay + dash), compressor, evaporator...then charge with refrigerant etc....the list goes on !!
It would be cheaper to buy same vehicle with aircon already factory installed.
Cheers,
2.6L Mighty Max 4x4 1988 has a blown head gasket...where would you look for a resonable rebuilt short / long block...or do you think it's worth trying to do a gasket replacement...189k miles...we live...
I'd at least invest some time and remove the head and look to see what you are working with. Have the head dye tested and also checked for warpage. if the head is OK, then do the gasket. If you severely overheated it, or if you had other engine problems before the head gasket failed, then I'd get a replacement engine ( many choices available from local craigslist, scrapyards and rebuilders ). Be sure to find the cause of the overheat that led to the gasket failure, otherwise you can do the same thing to the new one. If it's an automatic trans car, change the trans fluid also as it breaks down when it gets too hot.
1992 Mitsubishi mighty max computer i got is for a 2 whee drive. My truck is a 4 wheel drive will that matter
Yes, it will matter. When you purchase a used computer... you have to make sure that the "donor" truck has every option that your truck has. Like cruise, Int. wipers, and stuff like this. Both trucks have to be the same.
2answers
I dont know how big the gap on my spark plug should be its a 91 mitsubishi mighty max its 4wd and has a v6 motor
THE spark plug gap in the plugs when new are set but if you are cleaning and regaping then set them to 25 thou and you should have nomore problems.
Have a goodday
2answers
1989 how to change and were is it located the fuel
itz probly electric located in the gas tank like most new cars now u need to get a haynes or clymer manual that shows step by step-even then it takes some experience-take it slow are u sure the pump is bad check the whole fuel delivery system 1st a pressure regulator could be bad or clogged lines-please use jackstands
2answers
95 mitsubishi mighty max main required light
If you are speeking of the check engine light you can disconnect the battery for a few minutes then reconnect it and the light should go off.
2answers
Clutch problem
Likely need to buy a new clutch cable and install,and adjust for proper freeplay,and also possibly address the hole in the firewall .The hole needs to be looked at to make sure it is not oversized,cracked,bent,or otherwise unable to retain the cable.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
