Storing a Whirlpool Top load washer-- should I drain the pump? If so how ? Tks
    Scholar:
  • 58 Answers
Without the model i cant adv any products
the basics i always adv my customers is
Run once no detergent or clothes
Leave lid open
shut off water supply
disconnect all hoses
This is the best, most books give directions
but these are the basic steps, and will work
Posted on May 01, 2008
Our whirlpool washer is not finishing the cycle and gives an error code of F21 at the end of the cycle can you tell me what this is? tks Phil
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Mar 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine does not spin after washing...what's wrong? tks
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 27, 2010 | Asko W6021 Front Load Washer
My Whirlpool Washer will not spin tub
heatman101
Nov 01, 2010 | Whirlpool LSR9434PQ Top Load Washer
My Whirlpool Calypso Top Load Washer isn't draining or spinning. What can I do?
heatman101
Sep 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Need opinion on Washer repair
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22432100&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
See the following Whirlpool Service manuals for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Assuming that it WILL spin, but not drain, the problem does point to either a pump or hose problem.
If you can hear the motor turning during the spin cycle, the pump should be working.
See the following for how to remove the cabinet and gain access to / check the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=7eb3280b232f728490afcac4574c759e
If it will neither drain NOR spin, the problem points to the Lid Switch?
Apr 11, 2010 | Kenmore 22422 Top Load Washer
Whirlpool won't dump water- top loading washer - Ultimate care
check the tub on down to the pump located on the motor for obstructions, then to the hose leading to the drain from the pump for obstructions,then possibly pump is bad
Dec 24, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool front load washer wont drain or spin
Sounds like the pump quit working and needs replaced
Jun 15, 2009 | Whirlpool CAM2752KQ Top Load Washer
Whirlpool washer LHA780 drains very very slowly
you will need to remove the hose from the pump to drain and also from pump to tub.Make sure there is no obstruction in the hoses.You may want to look in the pump also.Hopr i fixya :)
May 21, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
