Question about Motorola Mobility RAZR V3
RAZR V3 FLEX
I am not familiar with technical language and do not know what you mean by changing the flex. Do I have to have a repair service do this? I have service with AT&T.
The v3 flex is the device connecting between mother boarb and lcd and the whole keypad as well, f you are not familiar with it, you better to refer to the service center near to your place
Posted on Jun 02, 2008
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile service center to have them reflash the flex file into your mobile.
My phone's keypad just lights up for few second the moment i turn it on then turns off again without a light on the screen .can you help me fix this problem?my phone is a razr v3 model.
Hi,when a Razor v3 has a light issues isuaully caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and the light.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Aug 17, 2011 | Motorola Mobility RAZR V3
Motorola v3 white lcd problem
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Jul 29, 2010 | Motorola Mobility RAZR V3
Black screen on RAZR V3
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
Good luck.
Jul 02, 2010 | Motorola Mobility RAZR V3
My phone pad doesn't respond??? The only button
Your motorola RAZR V3 cellular phones has a solution,Most V3 versions of phones have one specific problem.which is flex problem.when ever your using your phone and your keypads does not respond,No that is the flex cause the flex is connected from the screen to the keyboard.so you can change the flex of your phone.
Jan 11, 2010 | Motorola Mobility RAZR V3
Razr V3
i think the cable/flex is not compatible with your phone..
razor v3 flex is different from the flex cable of v3i..
wich one is yours?
Aug 30, 2008 | Motorola Mobility RAZR V3
V3 razr- battery
you should be able to get it from a mobile service center
Mar 05, 2008 | Motorola Mobility RAZR V3
Motorola Razr locks up when texting
try re-flash you language flex. google for a language flex then download it . it sud b compatible to your V3. use RSD lite to reflash it don't forgot p2k driver to connect your phone -google again.
google is the ans for those key i gave you. if you having problem find those let me know so i can upload them for you
Jan 14, 2008 | Motorola Mobility RAZR V3
HOW TO INSTALL THE OEM Motorola RAZR V3 Keypad LCD Flex Cable
1), remove the bottom part (completelly)
a) do you know how to open the bottom part?
2) remove the cover on the top part
a) disconnect the keypad LCD Flex Cable
3) remove the two chrome "big screws" that allows it to open and close
4) CAREFULL!!!! WHEN YOU READY TO SEPARATE THE TOP PART FORM THE BOTTOM!!
a) make sure the Flex cable is loose, and take a screw driver, push the ping on the other side (try to do this at the edge of a desk or table) keep pressure until this side pops out. KEEP IN EYE ON THE OTHER SIDE!! that the Flex cable does not get cut out by separating the two sides.
5) Replace and pop the two sides together.
6) Put everything back together.
let me know if I need to be more specific
Dec 07, 2007 | Motorola Mobility RAZR V3
Technical tips on V3
Guest - change the flex cable in the phone.
wallytackle - try and have the flex cable replaced...if that does not work then take the phone to a professional mobile technician and have them reflash the firmware on the phone.
Sep 26, 2007 | Motorola Mobility RAZR V3
Screen won't turn on
It's very possible that your phone's flex cable is either broken or disconnected from the screen.The flex cable would have to be replaced or reconnected. The reconnection is not too bad but replacing the flex cable is a way bit tedious.I'll choose the first option to see if this works. You'll have to take this to a qualified phone repair shop. These phones are very technical to work on even for someone who knows about them. SAM !
Jun 22, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
