Question about GE DBSR453EBWW Electric Dryer
Front load washer serial MZ401177W
Water does not spin out
  • 868 Answers
Remove the front panel if possible so you can access the water pump.If you cant remove front panel than there has to be one in the back.Locate the pump it will be a small motor with 2 hoses attached to it,and its sits on the base inside the machine.remove the hoses from the pump and remove what ever is inside it clogging it up.The odds of it being anything else is highly doubted.
Posted on May 22, 2008
My front load washer do not spin
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out. If helped, pl say so.
Apr 01, 2013 | Frigidaire FAFW3801LW Front Load Washer...
My Washing Machine is not spinning all the water out of my clothes.
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Frigidaire FAFW3517KN Affinity Series...
My Frigidaire Commercial Series FCCW3000FS 27" Coin Operated Front-Load Washer will not agitate or spin clothes out. Please HELP!
You should check your serial number at this link:http://www.cpsc.gov/cpscpub/prerel/prhtml09/09292.html
There was a voluntary recall issued on your model number. The serial number will confirm if your machine is affected.
As to your problem, i would still suspect drain pump is struggling or inoperable. However if it seems to drain ok and your pump is still relatively quiet except for a nice mellow steady hum (there should be no rattling sound) then i'd take a look at the pressure switch. The pressure switch sends the signal to begin agitation (water level in tub is full) and spin (water in tub is drained.)
Jan 03, 2013 | Frigidaire Commercial Series FCCW3000FS...
Model WPRE6100GOWT; Serial #AM931842G does not spin the water out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 25, 2011 | GE Washing Machines
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
I am having tremendous vibration and noise when in the spin cycle. Serial #XC33113241. Purchased in 2003
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 04, 2011 | Frigidaire ATF6000ES Front Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Neptune washer front load
I don't know if this applies to your washer, but the model #MAH9700 and a serial number from 10188468GA through 11683946GJ washers have been placed on a recall. To find out more, go to:
http://www.repairclinic.com/0098_11.asp
Oct 12, 2007 | Washing Machines
GE DBSR453EBWW Electric Dryer Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
