Question about Microwave Ovens
Jenn Air JMC7000ADW
WE have the Jenn Air Built in Microwave and Oven. The Jenn Air JMC7000ADW microwave is broken again for the 4th time in 6 years. I would like to just replace it with another microwave...any idea which microwave will fit in the space?
    Scholar:
  • 58 Answers
I would consider the
JMC9158BAW this is a 1.5 cubic ft, yours is 1.6, yours is about 24 inches and this one 24 inch, this model is a built in/countertop
the closet model you are going to find
Kitchenaid has the KBMS1454SSS 24inches comes with 27 and 30 inch trim kit
and KBMS1454S same specs just different model
Posted on May 01, 2008
How can i disassemble a jmc7000adw
Although most open via a screw at the top or left side of the control panel.
Some require the cabinet / casing to be removed. If there is no visible screws at the top or sides of the control panel. Then the casing will need to be removed.
Mar 27, 2012 | Jenn-Air JMC7000 Microwave Oven
I have a broken jmc8100 built in which is no longer available. What microwave can I drop into the space
Perko, I have the same problem and will be quite interested if you found a microwave oven that can substitute for the Jenn-Air JMC8100.
Oct 30, 2010 | Jenn-Air JMC8100 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air JMC7000 Microwave stop working
I have the same unit and age the JMC7000 everything appeared normal on the display and countdown etc...But it would not heat,I trouble shooted the problem and discovered it was a faulty door switch I replaced it and it works like new again.I ordered the part from www.repairclinic.com it's an easy fix.and costs a few bucks...
Dec 19, 2008 | Jenn-Air JMC7000 Microwave Oven
JennAir JMC7000ADW Microwave Oven Not Heating Well
Assuming the turntable is working and the power at the outlet is correct (110 to 125VAC) then you almost certainly have a failing magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first: http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 22, 2008 | Jenn-Air JMC7000 Microwave Oven
JMC7000ADW Blows circuit breaker
I've had this problem twice with our microwave. The hint to where the problem lies is that the breaker blows when you open the door at times. Inside the microwave are three microswitches; primary and secondary interlock micro switches and an Interlock Monitor switch. The switches are supposed to shut down the microwave if it is running and the door is opened. But, I've found the upper primary switch can stick internal at times and when the door is opened the stuck switch will, because of the way it is wired as a safety switch, cause either the fuse or possibly the main circuit breaker for the oven to pop. The reason the stuck switch blows the breaker or fuse is when the door is opened the interlock switch will cause the neutral wire from the AC power to be applied to the Upper Primary Interlock switch which normally should be open when the door is opened, but if the switch is intermittent or the contacts weld themselves shut the neutral line is connected direct to the "hot" side of the power line through the fuse and thermostat. The first time my microwave failed the switch had melted the contacts together inside the switch and the second time the switch became intermittent and would blow the breaker to the over ever so often. I suspected the switch the second time this happened and utilizing an ohm meter I checked the switch several times by opening and closing the door and once in a while it would remain closed instead of opening when the door was opened. Of course while trouble shooting the power cord to the microwave must be disconnected and use all safety precautions when working around the high voltage areas inside the microwave. I wrote Jenn-Air about the bad switch and the way it is wired into the circuit, but never received any acknowledgement. I suspect these microswitches are under rated for the amount of current that passes through the switch, thus they overheat and eventually arc the contacts together. I hope this helps explain the intermittent problem and could explain many of the intermittent blown fuse problems I see in these internet help sessions
May 09, 2008 | Jenn-Air JMC7000 Microwave Oven
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Stopped working
So it's dead? (No display, no inside lights, no beeps?)
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
763 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
