Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green blinking light
When it says to check power supply what exactly does that mean?
  • Mitsubishi Master
  • 8,617 Answers
The PWB , FMT and DM boards all have capacitor issuses with that chassis. If the power light is blinking there are 4 1000uf capacitors on the DM that need replacing. If you need more info let me know.
Posted on May 04, 2008
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
How do i repair green blinking light in motherboard and not powering up?
Why would you want to try to repair a working green LED?
But you need a manual, to check what the blinking light means. See how it flashes, because the board is trying to tell you what is wrong with these flashes. Like perhaps bad voltage, or bad RAM or ROM? or lost all settings.
Feb 12, 2015 | HP Compaq d530 SFF PC Desktop
I got dell optiplex 755 desktop computer in the power supply unit at the back there is a small button and a green light what are these for??
It help diagnose problems with your computer
A solid green light means the computer is operating normally.
A solid yellow:- the power is operating fine but your computer not processing data. This could mean there is a problem with the CPU or another component on the motherboard.
A blinking yellow light: power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode
Jan 29, 2012 | Dell Optiplex 755 Desktop Desktop Computer...
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
PC will not turn on blinking green light on power supply
The green light on power is blinking, it means power supply working in main power and the main supply not constant that time after constant the green light, then turn on the PC.
Thanks
Aug 13, 2009 | Intel SR1350-E Server Chassis...
Blinking green light front and back. Clicking sound from inside.
Do you mean the little green LED light near where you plug the power cable into the back of the computer? If that's the blinking light then unfortunately, this means that power is getting to the power supply but it is not going from the Power Supply to the Motherboard/Devices. The power supply is broken and is not converting the power from the wall to the proper voltage for the Motherboard/Devices. You will have to replace the power supply.
Call HP, and I hope you are in warranty and get it replaced for free or you can order the exact same one from HP that originally comes with that model. 1-800-HP-INVENT for their tech support line.
May 05, 2009 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Power supply board led green light blinks 3 times.
vscan is a voltage used to setup the picture for the panal. It goes to the y sus board. The problem is at the power supply or the y sus board. You can check these with a meter.
Jul 25, 2008 | Philips 42PF9630A 42 in. Plasma Television
Monitor wont turn on green light blinks but makes a clicking noise
hi there, light blinks constanly means a shorted electronics parts, most of it are in the horizontal sec., and power supply. check first the power supply if you have a constant voltage output, else your prob . is in the horizontal section. do somr test and check up. ty
Feb 18, 2008 | Samsung 460PXn Monitor
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
