Question about Vacuums
Water leaking from underneath casing when in use
  • vernon66 May 01, 2008
    Vax 082 compact steam cleaner. When in use,water leaks from under the casing leaving a puddle on the floor.
  • Lauren Junge
    Lauren Junge May 11, 2010
    On what are you talking about??
    President:
  • 1,673 Answers
Not familiar with this one, but sounds like you will need to take it apart, you may have a loose water line or one that is cracked or has a hole in it.
Posted on May 01, 2008
2 Suggested Answers
SOURCE: Vax 082 compact steam cleaner leaks
I have a Shark Steam floor cleaner (mop) tht I have used about four times since purchasing it earlier this year. Now it leaks instead of steaming (that was yesterday) and today when i plugged it in, it didn't do anthing! Just got hot and nothing else. Any ideas?
Posted on Sep 25, 2010
Hoover f7458-900 leaking when placing tank on
Hello! Test the clean water tank to see if it is leaking. Fill the clean water tank with water on both sides. Hold the tank up and observe if water leaks from the valves underneath the tank. If either of the valves are leaking the clean water tank will need to be replaced. To order a replacement tank follow this link > Search Results. If the tank is not leaking, but the cleaner leaks when the tank is placed on it, this may indicate an internal issue with your pump. We would recommend taking the cleaner to a Hoover authorized service center. Follow the link to locate the nearest service center to you. > Service Center Locator Hope this helps!
Jul 26, 2014 | Hoover F7458900 Max Extract All Terrain...
I have a hoover 5835-900 and it is leaking solution everywhere
You'll have to find out where it's leaking! Its not real hard. I will help you!
1. Fill the clean water tank. Check that the valve on this tank doesn't let water through when not on the machine. If it does this the tank is the problem.
2. Take off the 4-6 phillips screws holding the hood on to the machine. They will be on each corner underneath. Be Gentle! Do not break any of the plastic parts. Remove the hood.
3. Check where the clean water comes to a L valve. This valve is a very common problem. Place the water tank on the machine. DO NOT hold the handle down. Use paper towel to check for wet spots if you can't see where it is leaking. It should be fairly obvious.
4. If the water is coming from the "back" of the machine or the handle pry the cover off the inside of the handle revealing the hoses. The water release valves may be leaking. Be sure to check all hoses for cracks or breaks. Simply find the water.. and trace it back.
90% of the time it is the L valve which looks like this:
http://www.vacuummedic.com/product.php?id=231
Carefully put the machine back together not forgetting anything and test!
Good Luck!!
Aug 15, 2012 | Hoover F5835900 Upright Steam Vacuum
Water is coming from bottom when useing the hose.
Good Luck!!
Vac Dr.
Jan 12, 2011 | Hoover F6020-900 SteamVac Upright Vacuum
Hoover steam vac spin scrub leaking cleaning solution
The hose leading from the tank to the sprayer head on the bottom of the unit, or the tank is not seated properly or the tank has a hole or crack
Feb 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Shampooer leaves spots
If the spots are NOT at the center of the unit - you may have washed the brush roll. Older style shampooer brush rolls could retain a lot of water and it is all dirty in there. NEVER wash the brush. Just after you are done - raise the nozzle and let it spin freely for 10-15 seconds. It will be clean most of the time.
If you already did or if you will absolutely have to do it in the future - do not soak it. Set it vertically somewhere so water could drain and leave it to dry.
Do not make sudden moves while shampooing so the water does not spill from the tray.
If you oiled Kirby some time or sprayed WD40 somewhere - maybe it is coming out now (do not oil Kirby - it does not need that type of maintenance)
Hope this helps
Nov 24, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Polti Vaporette 2400
Not sure this is the solution as my steam/water was coming out from the front.  Although it didn't look like it initially, it turned out to be coming from the hose.  There's a little o-ring that fits on a spike in the hose attachment and that was split.  I replaced it and it's working fine again.  I got my o-ring (in a pack of 200 assorted sizes) from eBay for about £3 but that was only because I was too lazy to go down to my local plumbing/bathroom shop which probably would have sold me 1 for a few pence.  Much better than £50 to replace the hose!
Feb 07, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Vacuums Logo
150 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
