HeatSeal H800 Pro-R making a squeeking sound when rollers are turning
Remove both side covers, you will see some allen bolts in the end of each shaft, tighten those , also squirt a small amount of oil on to the shafts where they go through the bronze bushings. This should fix the noise.
Posted on Apr 13, 2009
My gbc heatseal laminator is rolling back and foward continuosly .even when reverse botton is not press. why
Can be for two reasons.
The synchronous motor in it is faulty, or there is something wrapped against the roller and it is lifting the spring or throwing it into reverse.
Contact GBC direct
GBC heatseal laminator Google Search
Sep 01, 2017 | Gbc Office Equipment & Supplies
How can I fix the edges of my laminator to seal.
make sure you are at 300 degrees temp, you can slightly adjust the pressure on each side by tightening down the 5mm hex nuts on top of each bearing housing. There is alot of foreign films out there right now that also have substandard glue that are causing all kinds of lamination problems. USA film always works
Mar 13, 2015 | Gbc HeatSeal Ultima 65 Laminating System
Laminator squeals
The paper is fed into the laminator by rollers usually a top and bottom, one of them is usually made of silicone(rubber) check to see if tose rollers are turning, you may have to pull some covers off to see the rollers, but usually you can look in the throat where the paper is fed in and see these rollers with a flashlite. Not sure of the brand, big or small laminator, good luck. If rollers are not turning, some are belt driven, some are motor driven, could even be a control board or switch.
Sep 24, 2013 | ACCO HeatSeal Ultima 65 Roll Laminator...
I have a heatseal h425 and it is making a loud sound when turned on. The rollers are not rolling and it feels very hot on the outside of the unit.
hi can you please open the laminator up and tell me if there is a rubber toothed belt on the cogs by the motor then i may be able to help.
May 10, 2011 | Gbc HeatSeal H425 Laminator
I hear a squeezing noise coming from the front of the treadmill when I run. Every time I land on the platform it squeeks.
take hood off and check the front roller. you mite have to take the side foot rail off to view the roller
Mar 04, 2011 | Nordic Track NordicTrack A2750 PRO...
I have a canon pc850 the roller is squeeking.
Wich roller?
If the sound is geting from drum unit, replace drum unit.
If sound is getting from bushings or axis apply small amount of wd40 or similar.
Jun 29, 2010 | Canon Office Equipment & Supplies
Dryer making a high pitched squeek, I took apart
I normally don't work on gas dryers but it sounds like the drum rollers are in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 27, 2009 | Amana LGA10 Dryer
Squeeking
The squeeking sound usually is in the fuser area
open the fuser roller area( clear paper jam the rollers are hot wait until it cools down get some spray silicone(similar to wd 40 with a plastic tube to reach small areas spray small amount on any e
xposed gears(plastic ) do not spray the fuser rollers
if you see nay other moving parts give them a light spray
turn back on and see if sound has stopped
If not try to determine when squeeking starts
then spary appropriate area
Dec 29, 2008 | Canon ImageClass D880 Copier
Rollers squeak when a fax is sent
The squeek is caused by friction if you have a steady hand get a bottle of 3 in 1 oil .. apply one drop of oil to each side of the roller ( make sure you put the oil on the metal pin that hold the rollers in place)Then feed a paper through so it lubricates those areas. this will stop the squeeking sound. Be very carefull not to get any oil on the roller. You want the oil on the metal pin that holds the roller in place. If you get oil on the roller use rubbing alchohol and a cue tip to clean it off. This is the safest liquid to use its not abrasive and it evaporates.
Sep 12, 2007 | HP OfficeJet 7310 All-In-One InkJet...
59 people viewed this question
 Grubhead
Grubhead
