Karcher 615 (bought new in 1994!)
Hi, my karcher recently after many years of good behavior started to...choke!
i called my service and they said its probably a valve...which wasn't very helpful as i opened it up and saw that there were many one way valves...and much dirt too..
they also wanted me to give them 250euro for a full repair....
so my question is...WHAT KIND OF FUEL CAN I USE TO REFILL THE PUMP as it was filled up with oil when i opened it? should i use valvolines that are made for gearboxes or a thicker oil like sae 30??
thank in advance alex...greece
Hi, I used 10W40, end its working gread.
Posted on May 30, 2008
1994 Honda VT 1100 C Shadow replace the choke cable
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Connecting replacement choke cable 94 VT1100
http://www.shadowriders.org/technical/chokecable.html
Honda SHADOW VT1100 Owners Workshop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda Shadow VT1100 Owner Manual
May 08, 2012 | 1994 Honda VT 1100 C Shadow
Bike wont start when cold,takes along time to finaly start.when hot starts all the time.thinking might be choke,how do i adjust choke.
Hi, Mikecardona0 sorry you can't find the first and best tool you ever bought for your Ducati despair not for a mere $0 you can download another one. For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.ducatimonster.org/forums/tech/166583-where-should-my-choke-lever.html
1994 1995 M600 Monster Choke cable conversion
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Aug 21, 2011 | 1994 Ducati Monster 900
1994 Suzuki GSX 600 F (Katana) how to replace the choke
Hi, Smkrepe for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Suzuki, despair not, for a mere zero $0 you can download another one.
http://katriders.com/vb/showthread.php?t=116054
Replacing your Choke cable on GSX600
Suzuki GSX600F Service Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
Suzuki GSX 600F 2000 Owner Manual
Dec 18, 2017 | 1994 Suzuki GSX 600 F (Katana)
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
May 04, 2009 | Karcher 2500 PSI Pressure Washer
Engine cuts out as you accelerrate when in nuetral.
You might have a coil problem or you might need a sparkplug cupor you need to synchronize your carbs.get your valves check also.
Mar 24, 2009 | 1999 Yamaha FZS 600 Fazer
Suspected problem with choke.
hey apparently and did are two different stories draining the float bowls and cleaning the carbs are two different things the fact that the choke dosent change suggest the carbs are stopped up after sitting for 1 year clean the carbs let them soak in carb cleaner and blow them out with high pressure air, keep notes of the adjustments befor you dissasemble them (air screws)
Jan 09, 2009 | 2001 Suzuki VS 800 Intruder
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Choke needs to be on all the time
your problem is in the carb. for some reason there is a stoppage or clogg in the venture opening that feeds the main passage to the manifold. that is the little pipe connecting the carb to the engine.the choke being on causes the engine vaccum to **** gas from other resourses in the carb to run. also check to see if throttle butter fly is moving freely.there may be a defect with the carb and they will have to replace. running the engine with choke on causes it to run rich and will foul the plug eventually . also not good on gas . will use way more than it should. also co2 level way up.
May 21, 2008 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
567 people viewed this question
Top Washing Machines Experts
