Question about Disney DTD1363-CAR 13" TV/DVD
Only stays on Channel 2 can't watch DVD's
Help I purchased a floor model of the 13" cars tv last night. (no remote, no box, no manual) Not a problem because it is for my 2 year old cars addict who just wants to watch the movie ALL THE TIME. WHen I plug it in to the wall and then run audio and video cables from DVD player to TV.. I cannot change channel on TV to watch movie. It only shows channel 2. I tried to use the menu to program tv.. but am not exactly sure what to do. I tried DTV and ATV. Can anyone tell me what I am doing wrong and how to solve? I also need a manual and a remote. Or a code to program a universal remote... HELP!!!!!!!
Sincerely
Not Mechanically enclined with "CARS"
  • jmccall2003 Jul 17, 2008
    is there a code to program a universal remote?
  • 4 Answers
Hello, get a remote from key electronics.
info@key-electronics.co.uk
they will sell a remote to you if they have them in stock , ask about a manual too.
ive spents weeks trying to get help about our tv and wow at last we have some...
christine.....
Posted on May 01, 2008
While watching a dvd on our ultravision tv i accidently pushed the channel button on our remote control instead of volume and can't get a picture now no matter what channel i put it on..lost the...
Look for "input" or "source" to get back to your DVD first (it may be AV1, 2, or 3). As far as the TV signal, it depends on what you have, do you have cable box?
Make and model of the TV will help also.
Jun 28, 2011 | Televison & Video
MY TV only goes to channel 3 and dvd mode and i dont have the remote that came with it can someone help me.
walmart, universal remotes from $7.00 and up, the problem should be that channels up to 3 were blocked and you need to re program channel search on menu, cable or antenna option and then, locate channels with signal, if you watch tv from cable, the channels search only detected the channel 3 as a channel with signal, if the tv is not hdefinition, you wont need more channels, if it is hd, there is an option for dvd, antena (hd signal of course) and hdm or whatever signals capability, I hope I helped you, othewise, contact me and I will be more than happy to help, God bless
Jan 26, 2011 | Philips 25PS40S 25" TV
We had no control of the DVD that we watched last night. No pause, fast forward, etc. Tonight, trying to watch another DVD and the one from last night continues to be playing and will not eject. Neith
Sometimes when you unplug the set ffrom the wall power or a while 1-2 minutes, and then plug it back in the problem will resolve itself. The DVD may eject. If it does, check it for damage, warping or dirt. If this does not fix it- you probably should take it to a repair center.
May 27, 2009 | Televison & Video
Hello I have a philips universal remote, don't know what model it is I thought all Universal remotes was one Model. Last night I tried using it for my TV to swich from TV to DVD and it just stopped...
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Dec 01, 2008 | Philips Magnavox Learning Universal Remote
Playing DVDs
try to use an Audio-Video(AV) cable(it has two or three wires,ask for it at the electrics shop),and push the button AV on your remote control.
May 24, 2008 | JVC AV-27230 27" TV
Cable stations interrupt while watching DVD
Remove power from your cable set while watching DVD and see if the problem magically goes away. If that's the case, the cable box is to blame...accordianman
Feb 03, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Classic dvd
The dvd player is at fault. Time to go shopping since repair not cost effective.
Sep 01, 2017 | Classic Electronics Classic DVD42S...
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Watching DVD or VHS ...
I could not find the manual for your TV, but I did find one for model number 27N-S50 so hopefully they're very similar. If you DVD/VCR is connected to your TV with composite cables (the RED, WHITE, YELLOW cable set) then you need to change the input mode. There should be a button labeled Input on your remote and pressing it will cycle between the various inputs (Cable, Input1, Input2). I would guess your DVD/VCR is connected to Input 1. If you have lost the remote you should be able to get to the other inputs by using the channel selector button. Tune the TV to either the highest or lowest channel in memory and then press either the CH UP or CH DOWN button on the TV to cycle through the various inputs.
The other thing you should know is that there is a recall on this TV related to the power button. I discovered this while looking for the manual on the Sharp website. Go to this website:
http://www.sharpusa.com/products/support/0,2309,,00.html
Type 27R-S50 in the model box and select Television/Home Theater Projectors in the Product box then click on Get Results and you'll get information on the recall.
Also, if the info I've given about how to select the input does not work, there are links on the above site to help you get the correct manual.
Lastly, I don't get paid for this. I know it's a strange hobby, but I like to help out when I can. I hope you'll take a moment and give a prositive rating if this information has been helpful to you. Nearly half of the solutions I've posted have never been rated. Thanks and good luck.
Jan 03, 2008 | Sharp 27R-S50 27" TV
DVD won't open
my open/close button doesn't work either. my model is 14PT6107S/05
Dec 11, 2007 | Philips 13MDTD20 13 in. TV/DVD Combo
Disney DTD1363-CAR 13" TV/DVD Logo
176 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
