Question about Motorola Mobility H700 Wireless Headset
H700 Battery Replacement - type & Supplier? - Motorola Mobility H700 Wireless Headset
  • 3 more comments
  • Anonymous Jun 14, 2008
    Battery wont stay charged
  • SuzaneSB Jul 12, 2008
    I bought the Motorola H700 to use with my new Sprint Katana DLX a few months ago. I have always had problems with it not staying charged more than 30 minutes. I took it in to the Sprint store immediately but they said I had to bring in the charger so they could check it out! So nothing happened. I wasn't sure if it was me or the device so I haven't taken it back yet. I wanted to check it out and be sure I was using it correctly first. I found that if I remember to turn it off every time I'm not talking it will last while I'm out but it's very frustrating to have to worry about time when it's supposed to provide 6 hours talk time and 30 hours standby. Anyone else have this problem?
  • howard_s Sep 16, 2008
    I have the same problem. I've charged it over night. It would run less than an hour when it starts to furiously beep in my ear for no reason. That is when my phone indicates that the signal is weak. It has to be the battery. I don't know how to open it to change it. Is there any help out there.
  • mlhh Jan 22, 2009
    I have had my H700 for nearly 6 months. Just this past week, it started not holding a charge. I charged the headset 2 hours using the AC adapter and as soon as I disconnect, the headset reflects orange. I have tried both the AC adapter and the car charger and have had the same results.
  • Olde yankee Mar 17, 2009
    Ditto, batteries don't last on these, and there is apparently no way to change the battery; is there???
What is the 16 digt code that my phone asks for
Posted on May 02, 2008
H700 charges fine, dies fast
You need to Change its battery For Your Head Set . Only solution is battery Change.
Mar 15, 2008 | Motorola Mobility H700 Wireless Headset
Replace battery h700
Well you can please follow the below step -
1. Make sure you actually need battery replacements. Wrong use of the unit can lead to faulty functioning. If you have recently bought the device, charge the unit for approximately 2 hours and let the unit drain its energy completely before recharging to give the maximum battery life span.
2. Turn off the unit before attempting a battery replacement. Without doing so, the power disruption that the headset will acquire can damage the internal workings.
3. Find the even **** on the bottom side of the unit, where the microphone boom is attached.
4. Place the edge of the flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up, however.
5. Find the small ring near the plug and the mini-USB port. Use the screwdriver to push under the ring where the battery is found. Push forward gently to pop the battery out. Please post comments for more help or information.........
Good Luck!!
Jun 08, 2010 | Motorola Mobility H700 Wireless Headset
Change battery on a motorola bluetooth H700
  • Find the even **** on the bottom side of the unit, where the microphone boom is attached.
  • Place the edge of a flathead screwdriver along these slits, and twist gently back and forth until the unit opens up. Do not completely open the unit up, however.
  • Find the small ring near the plug and the mini-USB port. Use the screwdriver to push under the ring where the battery is found. Push forward gently to pop the battery out.
  • Jun 07, 2010 | Motorola Mobility H700 Wireless Headset
    How do i get a replacement battery
    you will have to contact a local battery supplier im not sure where you live but i live near a store called battery all types they sell all the batteries you could ever need so try a battery store or electronic store if all local options fail then contact the supplier of the unit or the manufacturer direct
    hope this helps,ben
    Aug 10, 2009 | Protron PDV-288 7" LCD Portable DVD Player
    H700 charges fine, dies in an instant
    Open it and see if it has a battery. Take the battery to RadioShack and have them get you the correct battery. Use contact cement glue to put it back together.
    Battery needs replacement
    Hi alvaring
    Use a med/thin guitar pick and slip it under the edge of the casings and run it around the perimeter to snap open the casing locks. This method works for all snap together devices, and I have not found a better way yet!! Good luck. A FixYa rating would be great for this bit of knowhow..
    regards
    Graeme
    Mar 08, 2008 | Motorola Mobility H700 Wireless Headset
    Motorola Mobility H700 Wireless Headset Logo
    1,604 people viewed this question
    Top Motorola Mobility Radio Communications Experts
    Coss
    Dennis
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
