Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Is 5d or sd a code - Whirlpool Cabrio WTW6600SBT Top Load Washer
    New Friend:
SD is the code for suds detect. You may have used too much detergent, or you may not have used HE laundry detergent.
Posted on Aug 17, 2010
4 Suggested Answers
SOURCE:
  • 155 Answers
SOURCE: error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
If too much detergent was used:
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test.
Posted on Apr 11, 2010
rylee_smith
  • 8619 Answers
SOURCE: Problem draining. Getting 5d code.
Hi
Thanks for using FixYa. Error 5d means too much detergent was used. Try the following procedure---
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent. If still the problem persists, then please check the following things--
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jun 07, 2010
  • 135 Answers
SOURCE: troubleshooting code 5d or "Sd"
SD would be too much suds or the pump is clogged and can't remove the water fast enough.
Posted on Sep 05, 2009
Kenmore model 110
Per Sears Repair Site code 5d is actually SD. Indicating suds detection. It displays when a drag is detected by basket of a suds lock condition. This is generally caused by using too much laundry detergent or the wrong type.
Apr 13, 2014 | Dryers
Error code 5d
Ok the Sd error code (not 5D) indicates that the unit has detected too much suds and has shut down until the error is cleared.
Try running a load with no soap and that should clear the problem.
If that does not solve the problem, then you will need the service manual to perform further diagnostics to the unit.
Here is a link to the manual.
Oct 17, 2012 | Whirlpool Duet GHW9150P Front Load Washer
My washer is displaying a 5d code on panel, what does this mean?
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this problem you have to take the bottom front panel apart and then clean the drain filter pump assembly completely, make sure the washer is unplugged before working on it. Please get back to me if you have any other questions.
Kevin
Jul 01, 2011 | Kenmore Front Load Washer
Error code 5D
5D is actually SD which is suds detection. This could be because you are using non HD detergent.
OR
It happened to me when the discharge hose backed up because the sink into which it was discharging got backed up. It looks like the discharge hose not flowing properly is the most common cause of this error code.;
Nov 02, 2009 | Maytag Washing Machines
What does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Oct 20, 2009 | Washing Machines
Troubleshooting code 5d or "Sd"
Sep 04, 2009 | Washing Machines
What does F- indicate?
The SD code, is a sudsing code. If you are using the appropriate amount of soap and HE soap, it could be a communication error with the sensor and the CCU (the main control board). If you take off the panel on the bottom of the front (3 screws on the bottom hold it on). Once you get in, there is a plastic pouch on the right hand side there is a tech sheet that will have a list of all the error codes, and what to check.
Good luck
Dec 23, 2008 | Kenmore 43142 Front Load Washer
Kenmore HE2 front load error 5d
It is possible that instead of 5d that you have a SD. The SD error is usually form an excess of suds in the washer. In most cases you can run the machine through a couple rinse cycles and clear that right up. If that does not work then you will need to clean out the drain and your pump filter. The filer is located behind the bottom panel and you just unscrew it from the pump. If infact you had a 5D error then I am sorry for misinforming you, I have just never heard of a 5 D and I have been services them for years. I really hope this helped you, good luck.
Nov 12, 2008 | Washing Machines
Maytag Neptune Frontloading Washer
5d is actually Sd, which means too many suds. Make sure you're using "he" types of laundry detergent.
Jun 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
539 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
