Question about Dishwashers
Soap dispenser won't open
Sorry, thought I'd included them. Anyway the manufacturer is LG and the model number is L055811WW and the serial number is 610KWRE00118. Sure hope this helps.
    Scholar:
  • 150 Answers
Sorry can't get parts lookup for LG which is how I check for possible failures to point out to you
Posted on May 07, 2008
What is the year model of my rifle ?
impossible to tell you with out the most important detail, the serial number!
Just Google
Marlin model 922 serials
Marlin Manufacture Dates
oldguns.net/sn_php/marlinlookup.php
  1. Cached
  2. Similar
Marlin Lever Action Rifle Serial Numbers 1883 to 1906 (Including Models 1881, 1888, 1889, 1891, 1892, 1893, 1894, 1895 and 1897
Serial Number help on 922m - Marlin Firearms Forum
www.marlinowners.com > ... > Rimfires
  1. Cached
  2. Similar
Nov 7, 2010 - 10 posts - ‎7 authors Anyway the serial number is 922M62XX. I'm sure the first four are the model number, but I can't remember how to tell the last ones
Mar 31, 2016 | Optics
The soap dispenser door will not open during the washing cycle. What could be my problem? I have a Lg dishwasher model #ldf7561st
If you don't want to disassemble the dispenser to replace a part, you can replace the entire dispenser. Additionally, if the dispenser isn't working and the entire dispenser is worn out, replace the dispenser.
Sep 26, 2015 | LG Dishwashers
Frigidaire affinity soap dispenser doesnt work
Good Morning Friend, this is Z. I appreciate your post!
I see that you have a Frigidaire washer and that you are having trouble with the soap dispenser. Is the soap dispenser not dispensing bleach or softener? Is there water left in the dispenser? Are you able to open and/or close the dispenser? Also, may I have your model number please? You can normally locate the serial on the upper front, as you open the door. With this information I can better address the issue at hand. Thank you!
Jul 26, 2014 | Frigidaire Washing Machines
Help ! We have an L G front Load washer model # WM2016CW that leaks soap out the front bottom of the dispenser. It is 2 years old and I have followed all the manufacturers instructions on using HE soaps...
You can remove the dispenser and place it in the dishwasher for easy cleaning.
I have included some notes on your washer and I have a service manual for you HERE
Apr 07, 2011 | LG WM-2277HW Front Load Washer
The door of the soap dispenser opens but the soap is unused
The description is interesting as I have never heard of a microwave oven with a soap dispenser.
Please resend your question and include make and model.
Thank you
Jan 01, 2011 | Microwave Ovens
The soap dispenser won't open during the cycle on my 15782 model Kenmore Dishwasher. I am using gel pack soap...so I do not have old soap caked in the receptical. Any thoughts?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Oct 26, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
Model shy66co5uc/14 soap dispenser will not open during wash cycle. I can open it manually, but it does not open in any of the wash cycles.
Most likely the small sping that activates to open the soap dispenser is either broken or missing. You need to get this part from the manufacturer.
Dec 04, 2009 | Bosch Dishwashers
The soap dispenser opens but the soap is not dispensed and the dishes do not get cleaned. Can you help?
Make sure that there is nothing blocking the soap door from opening fully when the dishwasher is shut. This happened to me and I also thought that the soap door was opening during the cycle when it actually only partially opened during the wash and then popped open fully when I opened the dishwasher at the end of the cycle. So some, but not all, of the soap was used.
Dec 28, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
123 people viewed this question
Top Dishwashers Experts
