Sony TV KV-XR29M31 with supply blow-up. Fet Q608 and Q607 short circuit taking horizontal output Q and R642 .1 ohm. Is it caused by dried-out caps and does it take IC 602? Appreciate any help. Thanks.
  • 4,234 Answers
Replace the FETs with ones from Sony distributor. Do not substitute. Replace all of the small blue disc caps in the area. These can short causing the power supply to fry. In your case, the HOT probably was the initial problem, not the supply.
Dan
Posted on May 01, 2008
Sony wega KV-27FS12, light is flashing seems to be flashing 4 4
Hi
It seems you tv set has an overload in the output supply line which may be caused by a shorted rectifier diode or a shorted horizontal output transistor and associated circuit. The set should be serviced.
Sully
Sep 29, 2013 | LG RU-44SZ61D 44" TV
I have a Sony Trinitron 34" tv. It will not turn on. The red light blinks 6 times then pauses and blinks 6 times again. Is this an easy fix or time to get a new t.v.?
hi,
ur tv has problem with horizontal output stage. check the horizontal output transistor. if it found short replace the same and switch on the tv. if the same fault occur again, then the lot (line output transformer) may be faulty. also check for any dry soldering in the power supply stage and horizontal output sage.
ok
Jan 03, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The power went out while watching my Sony TV KV-32V16. I tried to turn it back on with no success. When I push the power button I hear a click, but the TV does not come on. How do I repair.
The problem is from the power panel of the television. It got burnt due to the voltage that hit the panel.
Mostly, it's a capacitor that gets burnt on the panel, so what you have to do is, open up the television with the appropriate screwdrivers and locate the power panel, it is attached to the main cord that is connected to the power supply.
Assess the panel, and check for the burnt capacitor that is on the panel, or you can as well replace them power panel.
After doing this, your television will be in good condition once again.
Take care and good luck
Oct 08, 2010 | Sony KV-32V16 TV
Standby light blinks you hear the contactor clicking in set, no audio and no video displayed. sony kv-36Hs500 only looking for response if this is free of charge
this symptom is usually caused by a breakdown in power supply circuit or it may also be caused by a breakdown in the horizontal deflection circuits which includes horizontal oscillator, pre drive or drive circuits, horizontal output transformer, horizontal output transistor and high voltage circuits (flyback transformer). pls observe precautions in dealing with this high voltage circuits and if so happen you are not inclined with this kind of work, it is better for you to bring it to a qualified technician to avoid accident. good luck!
Jul 27, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
I have a Sony KV-32S20 32" TV and the red standby led flashes constantly. From what Ive read does that mean an an I.C. tv chip # mcz 3001d is bad? I also read that replacing the R-536 with 1 ohm resistor...
you first must verify you have horizontal deflection. do the crt fillaments light up? if they dont you probably have a shorted horiz. output transistor short or a bad solder joint in the drive circuit. i would solder this anyway it is a common issue. it can blow up the power supply if it fails. if they do light up turn up the screen control, the bottom control on the flyback transformer, do you have a flat vertical line? if so you lost vertical deflection. that could also be a bad connection on the ic or it failed.
Dec 28, 2009 | Sony KV-32S20 32" TV
HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Apr 15, 2009 | Televison & Video
Snoy model KV-21GMR1
check secondary voltage first and look for short.if you replace the regulator strs6707 you replace also c623 220uf/16volts
Sep 24, 2007 | Emerson TC0918 Television
No power.
Usually, in those Sony sets, a crack developes on a small transformer in the horizontal drive circuit, which causes the horizontal output transistor to short. This immediately shorts out the switching transistors in the power supply and blows the Sony 0.1 ohm resistor fuse. A shorted flyback (high voltage) transformer will also have the same result. The power supply does NOT need to be replaced. The parts should be replaced, the flyback checked and the board resoldered by a qualified tech familiar with Sony sets.
Aug 23, 2007 | Sony KV-32V35 TV
Sony TV 27" KV-27V36
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician. i cannot tell you the cost to fix your tv coz my location is in the Philippines.
Jan 18, 2007 | Sony KV-27V36 27" TV
KV-32S26
It is definetly a power supply problem shorted bridge ,switched mode transistors DO NOT TRY to fix if you dont know what yor doing I got 30 years in it.GOOD LUCK. WAYNE
Oct 22, 2006 | Sony KV-32S26 32" TV
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
Electro Med Services...
