Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
My boiler keeps firing up even when the Honey well programmer is in the off position. The programmer is about 7 years old.Do I need a new one, a new battery for it or is it to do with the boiler (oil) itself? Gail
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Jo
Posted on Apr 23, 2009
How do I fix a problem with my boiler not coming on?
Ive just resolved this issue on my own boiler...... Its the programmer ,replace it as the micro switch has gone , when it comes on the lights only come on the internal switch does not ,so no sognal to boiler , replace programmer
Aug 01, 2016 | Water Heaters
Boiler not coming on, programmer constantly flickers on/off
if voltage from transformer ok check to pressure switch bad or loose wire
Aug 01, 2016 | Honeywell Water Heaters
Ideal classic se24ff
Check wiring on the new programmer,sounds as if you have wires crossed.
Sep 12, 2017 | Water Heaters
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
Heating not working and Honeywell Thermostat Heater states that the temperature is 45 degrees celsius.
without seeing it its hard to say, the thermostat controls the boiler and/or diverter valve depending how its been wired, the diverter valve shunts the water to were its needed ie from one circuit to another if you have two therostats there is a conflict somewere, best bet to have an engineer sort the wireing out
Dec 28, 2011 | Honeywell Programmable Thermostat Heater
I have a boiler system that was turned off at the thermostat for about 5 min. when turned back on it never clicked on again it has a new honey well aquastat relay, new pilot and prob only three months old....
Take off the thermostat and jump the red and white wires together. The boiler should fire up. If not, you will need to check if the boiler has power to the control. It could be a fuse that burnt.
Feb 14, 2010 | Honeywell Programmable Thermostat Heater
My honey well thermostat keep clicking and I can't program it
If you have a programmable thermostat and it is a couple of years old you will probably have to install a new one. What kind of thermostat do you have? You can turn power off to furnace and then take thermostat off wall and take wires marked r & w and connect them together your heat should come on when you turn power back on. If not you could have blown the 5 amp fuse inside furnace. I would check the fuse inside of furnace. If you take panels off front of furnace you should find a controll board inside that runs furnace.If you have anymore question just reply back to me
Jan 07, 2009 | Honeywell Programmable Thermostat Heater
Alpha boiler - wireless programmer failing
it sounds like the problem may be in the boiler and not the controller itself. Do you kno which is are the two wores that are the r-w for the thermostat take and purt them together and see if the boiler stays on or shuts off like it does with the thermostat. If it does then replace the reciever. If it doesn't then you have another problem. Good Luck
Jan 05, 2009 | Water Heaters
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
838 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
