Question about Whirlpool AWZ410 Front Load Washer/Dryer
My whirlpool awz410 is not spinning
Machine is on
- water is pouring in and draining too
- i cleanedd the filter
still my machine is not spiining, it sits there making grinding noice
any help would be great :)
  • Anonymous Sep 10, 2008
    Filling & draining ok but not washing or spinning!!!!!!!!!!!! Help
  • Anonymous Sep 16, 2008
    Same here, not spinning at all in either washing or spinning mode.
    New Friend:
Just had a the same problem, with the aw410 took the back off the machine and the rubber belt that connects the drum to the motor had fallen off, I just had to reattach the belt and it's working fine now. hope this helps.
Posted on Sep 19, 2013
  • 868 Answers
If its draining while its filling ,raise the drain hose higher than the water level and it wont syphon.
Posted on Jun 05, 2008
It shoots too much water coffee come out watery
try adding more coffee to the filter, or making the grind FINER or both
Mar 08, 2011 | Coffee Makers & Espresso Machines
MY SPIN CYCLE NO LONGER WORKS. MY MACHINE MAKES A NOICE BUT THE WATER IS NOT GOING OUT. THE DRUM STILL TURNS WHEN YOU WASH IT JUST NOT WHEN IT REACHES THE SPIN CYCLE
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 28, 2011 | LG WM1814CW Front Load Washer
Just bought a new Bunn Thermafresh and it overflows coffee grounds and coffee all over. What can I do?
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Don't overfill the basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Make sure that the Pause 'n Serve button isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
Nov 04, 2009 | Bunn NHB Coffee Maker
Coffee has doesn't drain into the carafe and just overflows all over the counter
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine or too course. (See instruction manual.)
4. Make sure the filter cone/basket clicks into place and that the carafe is pushed all the way in.
7. Make sure that the Pause 'n Serve isn't sticking. (If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.)
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Make sure the coffee machine is sitting level on the counter.
Oct 05, 2009 | Zojirushi ECBD15BA Coffee Maker
Coffee maker with grinder--sometimes, when percolating, it overflows
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
Jun 28, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Bunn coffee pot blows water out top of basket
Check the grind on the coffee, brew a pot without coffee and if it overflows, then the machine has a problem. If it doesn't then try a coarser grind on the coffee.
Jun 14, 2009 | Bunn Coffee Pots: Thermal Carafe
Cusinart 12 cup grind and brew overflows with grinds and water
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
Apr 02, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Water sitting in well (where the coffee goes) - doesn't drain
Some fine-grain coffees are too fine for the Gold Tone Filter. If this is the case, remove the Gold tone Filter and use paper filters only. You may have to wash excess grinds out of the black filter basket, since there may be a few stuck in there now - don't take the filter basket apart - just rinse it out with water.
Also, don't use a paper filter and the gold tone filter at the same time.
The brew-pause feature is somewhat limited. You can remove the caraffe quickly, pour, and quickly reinsert it, but there is going to be some drippage during the process. You also have to replace the caraffe back in place quickly, or the coffee will overflow the basket.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 21, 2009 | Cuisinart DCC-1200 Coffee Maker
Water overflows from filter basket
Dec 25, 2008 | Mr. Coffee ISTX95
Grinding noice
more then likely that the pump has some kind of blockage in it this will cause the washer not to empty fully which when it goes onto spin it will bang about due to the water going from side to side check the pump will be underneath just were the drain hose goes into the washer you will have to strip to get the blockage out once done it should work fine m8
Nov 27, 2007 | Hoover HW6 160M Front Load Washer / Dryer
Whirlpool AWZ410 Front Load Washer/Dryer Logo
204 people viewed this question
Dan Webster
Dan Webster
Sal De
