Hey, did you ever fix your nokia 6300 microphone problem? mine quit on me recently after changing the housing.
Hi, I too changed the front cover, middle section and battery cover including keypad. Firstly I couldn't get any reception and now if someone rings it just vibrates, no sound comes out, they can hear me but I can't here them etc... I guess that by changing the facias ourselves we have damaged something inside. I am taking mine to a nokia repair shop and see what they day. If anyone has any other ideas about how to fix this please let me know!
U just have damaged its earpiece and buzzer or u just forgot to move it from ur older middle section to the newer one
Hello, there I have the solution to remove the mic discovered by myself. get a metal screwdriver and heat the tip for about 20 seconds on a flame then push it through the back of the case behind the microphne and it should just pop out.
Himans is right, you just need the parts from your older chassis, put the 2 chassis together & take parts from the old chassis 1 at a time & add them to your new one, then you can't go wrong :o)
It will just be something you have missed.
At the bottom near the phone charger is a round mic. You need to take it out of the old phone and put it in the new case. Dont ask me how to get it out as I am struggling
Just get a pin and lift it out it's only rubber
Use a pin - it will pop out from the edge
I want to ask ..? each of my phone ... but no sound ... I change the mic ... but his voice just does not exist mashi,,, please how to fix it ..?
