Question about Technics SL-1210 Turntable
Technics 1210 Distorts
I bought a pair of 1210s off eBay and they worked fine for some time, but then they started distorting, mainly in lower frequencies. I thought that instead of paying to get them serviced I would install my rega tonearm from my regular turntable, which works fine. I did this, but I still have exactly the same problem. I'm completely baffled about this one because I don't see what else other than the tonearm could be causing the problem. Please help!
  • 515 Answers
Well, if it's not your tonearm, then the issue is either your RCA cables (red/white), or your cartridge/stylus.
There is nothing else on this unit that would cause distortion in sound. Well, unless you have the unit sitting next to a very powerful electrical source. Try a different outlet as well, just to be on the safe side that it's not electrical interference.
Posted on May 13, 2008
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
I have two technics 1210s. I was away on holiday for 3 months and when I came back neither would switch on. I have changed the fuses and still neither turn on. Any ideas on what could be the problem?
i got my turntables repaired by these guys
i did they made my setup work like new so im going to spread the word.
give them a shot
Apr 08, 2010 | Technics SL-1210 Turntable
Me technic 1210s wont *** on ive tryed change in the fuses wiv 1 from tv an still nothing any ideas?
It could have got an internal fuse, not the one in the plug. Also the power switch might have broken. There's only one way to find out! Take the bottom off and have a look.
Jan 12, 2010 | Technics SL-1210 Turntable
Tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or
touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
Aug 04, 2009 | Technics SL-1210 Turntable
Technic 1210 deck
Make sure your 2nd turntable is connected to the PHONO input of your DJ Mixer or Receiver. If you have it connected to LINE IN or AUX IN, the turntable will be very low, as this model requires a phono pre-amp to amplify it's signal.
If this is set up correctly, then you might want to check your cartridge. Can you swap the cartridges out to see if the problem remains on the same turntable, or if it switches to the other turntable. If it switches, then you know the problem is with the cartridges.
If that checks out ok, you might have an issue with the RCA cables or Tonearm or both. At this stage, I would suggest taking it to a service center for assistance.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Apr 17, 2009 | Technics SL-1210 Turntable
Poor quality sound
Double check all your cables. The only 2 things that affect sound on the 1200s is the RCA cables and the tonearm. I would first replace the RCA cables to a better quality set.
Technics Repair Videos
Technics Turntable Repair
DJ Equipment Sales
Technics Parts Sales
Jan 16, 2009 | Technics SL-1210 Turntable
No Power to 1210s
Problem is not the fuses, but the power supply / power transformer has blown. This is why you should always wrap exposed wiring with electrical tape or heatshrink tubing.
The power supply can be purchased HERE, but this is not an easy replacement. And if you blew it by not properly replacing the Pop-up light, than I DON'T suggest you try to replace the power supply on your own either. You could really cause even more damage, and possible harm to yourself and your property.
Turntable Repair Expert
Digital Analog Therapy
Nov 22, 2008 | Technics SL-1210 Turntable
Technics 1210 pop up light?
Maybe you should try putting a smaller (in Watts) lamp in the pop light...
Nov 09, 2007 | Technics SL-1200MK2 Turntable
Technics sl 1210 turntable
What sort of problem are you having with the cords?
Sep 04, 2007 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
143 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
