Question about Nokia N73 Cellular Phone
N 73 i carnt gt any bars of service it wont let me call or anything. is there a way i can like reset the service settings or somthing arather
    President:
  • 1,017 Answers
If it's a signal strength problem, it's more likely to be your Network Service Provider than your phone. However your internal aerial might be faulty.
You could try a restore to factory settings, but I don't think it will change anything.
Updating the Firmware might help.
-_-_-_-
You need to download the latest Nokia PC Suite to do an update on your phone.
Before updating software you should check that there’s a newer version of software available.
WARNING
When updating software on Mobs, be sure to:
HAVE A FULLY CHARGED BATTERY INSERTED;
PUT IT ON GENERAL PROFILE;
TURN OFF YOUR PIN NUMBER;
CONNECT YOUR CHARGER TO YOUR MOB AND SWITCH IT ON;
DO NOT ----- DO NOT ---- TOUCH YOUR PHONE WHILE THE UPDATE IS GOING ON;
THIS CAN TAKE 30 MINUTES OR MORE.
And obviously don’t unplug the phone from the PC.
Be patient, you may have to do a restart or two on your mob afterwards. Even remove the battery to get it going again (not recommended). But give it plenty of time.
It is also wise not to use your PC while updating software, just in case the PC freezes.
If the PC freezes during an update, you’re up the creek without a paddle...
I did an update on a Sony Eric 810i it took nearly two hours.
More... Your phone turns itself on and off, sometimes more than once while updating software, you should leave it well alone during the update.
Posted on May 20, 2008
  • Elninodan Jul 08, 2011
    Go to settings,then network, put ur network on gsm
How do i hard reset my lg uk 410 tablet
Settings --> Resent menu 9.
Reset settings menu--> Master Reset options YES --> enter your 4 digit security code. The default code was 0000 unless you changed it. This will delete the phone entries. Security menu allows changing security code. You did backup anything you wanted to save, right? Note that customer service may remotely repair some phone problems.
http://www.hard-reset.com/lg-410g-hard-reset.html
Jul 08, 2015 | LG Tablets & eReaders
What is call barring code for nokia1110?
Select Menu > Settings > Security settings >Call barring service
Select one of the barring options and set the option on (Activate) or off
(Cancel) or check whether a service is activated (Check status).
Ref:
http://nds2.nokia.com/files/support/apac/phones/guides/Nokia_1110_APAC_UG_en.pdf
Jun 14, 2014 | Nokia Cell Phones
Want to reset security access code on my Nokia
To set how your phone uses the access codes and security settings, select Menu >Settings > Security.
The security code helps to protect your phone against unauthorized use. The preset code is 12345. You can change the code, and set the phone to request the code.
The PIN (UPIN) code, supplied with the SIM (USIM) card, helps to protect the card against unauthorized use.
The PIN2 (UPIN2) code, supplied with some SIM (USIM) cards, is required to access certain services.
PUK (UPUK) and PUK2 (UPUK2) codes may be supplied with the SIM (USIM) card. If you enter the PIN code incorrectly three times in succession, you are asked for the PUK code. If the codes are not supplied, contact your service provider.
The barring password is required when using the Call barring service to restrict incoming calls to and outgoing calls from your phone (network service).
To view or change the security module settings, select Menu > Settings >
Security > Security module setting
OR
can look for::
http://www.unlock-free.com/nokia-master/
good luck!
Dec 28, 2013 | Nokia Cell Phones
How do I reset my default setting
Go into your Window -> Setting Preferences -> Edit (on the menu bar on top) and there you find Restore Settings to default. Some settings wont be reset such as shortcuts for viewports etc. Hope it does the job for you
Sep 12, 2012 | Cameras
Hi, I am unable to login into yahoo mail . After filling in the correct username & password, the page returns back to login page.
Your browser's cookies may be disabled. If you're using internet explorer, go to tools > internet options > privacy tab, then set the bar to either medium or low. If it still doesn't work, try reset your ie (internet options > advanced tab > reset) or use another browser (firefox, google chrome, etc.)
Apr 06, 2011 | Yahoo Mail
I have bsnl 3g sim, how to configure gprs in htc wildfire a3333
BSNL 3G Configuration for HTC Wildfire (A3333) - Postpaid Connection:
1. Speak to BSNL customer Service center and get the confirmation whether 3G service is activated.
2. Menu -> Settings -> Wireless & Networks -> Mobile networks -> Access Point Names -> New APN ->
APN: bsnlnet
don't change anything else and just save the settings.
3. Under 'Network Mode' the option selected should be 'GSM/WCDMA auto'
4. Menu -> Settings -> Wireless & Networks -> Select 'Mobile Network' to connect to internet and look for see letter 'H' at the top near the coverage bars.
5. Lauch the browser and check 'Google.com'
Its working fine for me after a long struggle with BSNL customer care, Finally got fixed by applying the above fix.
Jan 26, 2011 | HTC Wildfire Cell Phone
My iPod touch wont charge at all and it wont turn on or anything
Try one of these steps:
- Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
-press in the sleep/wake button on the top left of the device, and the big circular home button on the front face on the bottom. Do this for roughly 10 or more seconds and the device should shut down/off. Give if a moment and then restart the device.
-*WARNING* This method can erase all of your personal content on iPod...
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
  • If that doesn't work, restore the iPod touch software. See "Updating and Restoring iPhone or iPod touch Software."
Mar 11, 2010 | Apple iPod touch
Nokia n 73 signal disappear
Sounds like you're getting 3G interference. It happens because you're just on the edge of a 3G area. The same happens to me on both my N95-8GB and N73. The phone is detecting a weak 3G but it's not enough to make a call.
You need to go to "Tools" -> "Settings" -> "Network" and switch from "Dual mode" to "GSM" The phone will say it needs to restart, select "Yes"
The phone will then restart and you shouldn't suffer any more 3G blackouts.
Hope that helps.
May 22, 2009 | Nokia N73 Cellular Phone
I have a megxon k9 and carnt seem to put a memory card in it, i could before, but now it wont click in, iv tryed diffrend cards, but it seems somthing is blocking it, though i carnt see anything
you have to take the camera to peices and then replace them with higher quality peices.
I work at Curry's and we have figured that this works,
Nov 09, 2008 | Cameras
Nokia N73 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
