Question about Toshiba Satellite A105 Notebook
Toshiba power charging problem
You suggest it might be the port - which was my thought as well. but i didn't now what an ASP was - can you explain? thanks!
  • Anonymous May 19, 2008
    why is my laptop not recieving a charge?
    President:
  • 778 Answers
I will suggest posting this in your original thread, or starting all over and giving the original details so we can help you, as there are many of us and I for one don't know who you are asking.
Posted on May 07, 2008
My toshiba l40-14n won't charge and will only stay on for about 2 mins when connected to power supply: help?
There are only three parts from the Toshiba laptop that could be wrong:
1. Power Supply/Charger
2. Damage battery.
3. Electrical input port.
First, troubleshoot the charger, you can try it with another Toshiba laptop of the same model, if it shows that is charging, then then troubleshoot the battery.
To TS the battery, just get a battery from a friend, or if you can go to a store where they sell batteries, take the laptop with you and let them know that you want to test it first.
If the battery is not the problem, then you have a faulty electrical input port.
I had a Toshiba Satellite, also, I'm I.T.
Jun 26, 2017 | Computers & Internet
Obd2 port not recognising diagnostic tester
First I suggest to check fuses; keep in mind that the OBD-II port didn't work because the power wire in the connector corroded and didn't have a connection anymore. No power equals no OBD worked.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 17, 2012 | Hummer H2 Cars & Trucks
I have a 46 inch 1080 P Toshiba TV the green light came on the TV didn't come on then the green light didn't come on anymore what could be the problem I had the TV for a month today
If set is new and only a month old have it repaired under warranty. If no light for power at all now I need to know the model number to give suggestions as to what is wrong.
Apr 22, 2012 | Toshiba Televison & Video
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
My Toshiba's laptop's sleep and charge USB port
It's possible to fix. First go to device manager and you should see something like "USB Root Hub". Double click to open it, go over to power management, and "Uncheck" "Allow this computer to turn off this device to save power". Do this for all that say USB Root Hub. Next go to "Power Options" then "Edit Plan Settings" (accessible through "choose when to put the computer to sleep") and select "Change Advanced Power Settings". Next, make sure you do this in all of your power settings, but scroll down to an icon called USB settings. Expand the selection, then expand the "USB selective suspend setting". Choose, both on battery and plugged in if you want, to Disable the selective suspend. Finish and apply. Also, to confirm, you know that the USB device (IPod) but be plugged into the eSATA port, correct? It doubles as a USB port and is the only one capable of charging.
Mar 29, 2010 | Computers & Internet
My toshiba a205 s5804 is asking me a bios password
remove ac supply and battery from the laptop.. and press power button for atleast 30 sec.. it reset the CMOS memory.. this is what toshiba technical support person told me to do when i called to them way back..
Nov 04, 2009 | Toshiba Satellite A215-S4747 Notebook
USB ports not working. Any ideas?
In that case ,
Click on start and run
Type devmgmt.msc
Then uninstall all devices under universal serial bus controller.
Then need to click on any option in the list and scan for h/w changes.
This will install all devices back and your system will be able to recognize all devices now.
Hope this help.
Cheers!!!!!!!
Jun 21, 2009 | Toshiba Satellite A135-S2276 Notebook
My mobile won't charge from USB port
in your laptop goto device manager. universal serial bus controller. go to appropriate port. Right click- properties - there you will c a power management tab. uncheck Allow the computer to turn off this device to save power. click ok.
Jan 19, 2009 | Toshiba Satellite U405-S2826 Laptop
Power issues in toshiba s1800-911
Sounds like you have a problem with your power adapter, battery and or charge port ... I would suggest you let the unit "charge" overnight and try again.
Dec 22, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A105 Notebook Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
