Question about Zebra LP 2844 Thermal Printer
Zebra LP 2844 doesn't stop feeding paper
We have a Zebra LP 2844. For some reason, whenever it tries to print, it will just spit out paper until you power it off. It does this when trying to print from a pc as well as when it gets to the end of the auto-sense function. I've tried flashing the firmware but it is still doing the same thing. Any Ideas?
  • 4 more comments
  • TriGa May 04, 2008
    Im having almost the same trouble with this printer. When I try to print out something, it first spits out 8-10 labels and then starts printing arbitrarily on the next label. Any solution?
  • The IT Guy May 05, 2008
    I have not yet found a solution to this problem. I am hoping that someone on here will be able to point me in the right direction. In my original post, I said that it will feed paper until you turn it off. That isn't the case. It is like you said, it will feeds about 10ft of labels and then print the label you wanted.
  • The IT Guy May 07, 2008
    I have tried the Media Auto-Sense function. It will act as though it is working, but then when the printer gets to the part where it prints the report, it feeds out 10ft of labels before printing the report.
  • The IT Guy May 30, 2008
    I tried the procedure suggested in Solution #2. It made it so that it didn't spit out 30 labels before printing. However, Now, the printer prints one page and locks up, doesn't accept any print jobs, feed button doesn't work, the only thing to get it out of this state is a power off/on. The indicator light stays green however.
    The solution that I mentioned above was the one posted by jigeo.
    Alright. Here's what appears to be happening. The printer will now print a single page. It won't feed any labels or print another page until I tear off the label that is hanging out of it. Once, I tear the label off, I can press the feed button and it works fine.
I had the very same problem but I know it could be several different reasons. In my case it was a media calibration issue. To perform calibration switch the power OFF, then pres FEED button and hold it, Power ON still holding and after three red flashes release it. Calibration report will print out. At the end of that print you should get "PRESS FEED TO END". Do it and it should be ok. Let me know if that worked.
Posted on May 07, 2008
  • 57 Answers
This will only work if you have the ZUD4 drivers installed:
1. find the printer in Printers and Faxes, right click on it and select properties.
2. Click on the printer tab at the top. Click on the plus sign in front of Advanced and then click on the tools button
3. Click in the Direct Command for Printer box and type OD(case sensitive) and then click send. You will have to manually remove the contents before entering the next command.
4. Hold the shift key down and press the 6. You should see this: ^
Then press send.
5. Type default after the carrot; ^default
6. Click send.
7. Clear that and type xa and click send.
8. The printer should start 'reading' the label. When it stops moving, press the feed button.
9. Run a test to check but it should be correctly calibrated now.
Posted on May 30, 2008
I had the same problem. One day it just started screwing up. Here's a good test that determines if it's your PC or not. First, send the command ^default to the printer. There's a box under the printer properties to do this, though it's not 100% necessary.
The main thing is to see if it still runs past the label end if it's not connected to the PC. Unplug the USB and cycle power on the printer. Then try to advance a label. If it spits out more than one then the problem is in the printer and has nothing to do with drivers or anything else in your PC.
Open the printer and about 1/2 inch back from the roller you will see a small rectangle hole. This is where the LEDs are that sense the label spaces. If it's dirty or dusty this can cause the label to keep advancing. A more common issue is the sensor opposite the one I just mentioned, Open the lid and look under it. In the center near the thermal pad you'll see a small round hole. It should line up with the rectangular one I mentioned earlier. This was my culprit. The reader behind that little hole comes loose after time and moves. All it takes is just a fraction of a fraction and the printer will not stop after printing a label. I just took a kitchen knife and spun it a few times in the hole to widen it. Be careful not to hit the sensor when you do this. Once I widened it the printer started working like a champ.
Posted on Jul 21, 2008
Trash that ****, buy HP or something
Posted on Mar 10, 2009
  • Kailyn Sharp
    Kailyn Sharp Oct 24, 2013
    HP has never even dreamed of making a printer that can do what this printer does, as well and as long as it does it. We routinely see printers that have put out 150,000+ 4x6 labels and are going strong.
Headupx that helped me thanks
Posted on Aug 19, 2008
Zebra LP 2844 Thermal Printer, keeps staling
try to reset to favtory default and do a test print, download if needed other driver (www.seagullscientific.com.) reset to factory default with this driver and try a test page. Hope it helps. Paulo.
May 01, 2014 | Zebra LP 2844 Thermal Printer
My Zebra ZDesigner LP2844 feeds a blank label after printing a label. How do I make it stop doing that?
Define your label size correctly. Measure your LABEL exactly, do not include the backing paper or the gap. Calibrate the printer. HOW?
Power off printer. Press and hold the green feed button down and power printer on. Count one, two and release green button. The printer will calibrate and move labels and then print some stuff on the label. Wait until it has comletely stopped. wait another few seconds and the press the feed key once. The printer will print "out of dump". You should now be ready to print again.
Aug 31, 2013 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 is stalling out on every print.
Maybe the printer is not getting a good calibration on the label. If the status LED is a steady RED when trying to print, then the printer thinks its out of labels. A manual calibrationi could solve that.
1. Turn the printer off
2. press and hold down the FEED key while turning on the printer.
3. keep pressing the key until the status light flashes once, then let go
4. The printer will auto-calibrate for the size of label and then should be ready to use.
Press FEED once after its done and 1 label should feed.
Hope that helps !
Apr 06, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 spitting out blanks
Look at the stocks tab in the driver. There is an area in your print driver to adjust the width/height of the kind of label you are trying to use.
Apr 08, 2009 | Zebra LP 2844 Thermal Printer
Zebra Printer LP 2844 not feeding
Thanks for the response. It turned out to be a faulty power supply which did not send enough power to turn the printer. now it works like a champ
Apr 06, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844 tis not detedting the paper.
It turns out that I kept overlooking one printer setting. It was set for thermal printing rather than direct.
Mar 19, 2009 | Zebra LP 2844 Thermal Printer
Zebra 2488-z
Have you tried cleaning the sensor? It is underneath the labels oppoistethe print head.
Oct 18, 2008 | Zebra LP 2844 Thermal Printer
Printer won't print
check for paper jam and the ink.
green flashing lights means it try to print but something is holding it back.
Oct 14, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 prints blanks
If the printer is printing nothing but blanks, try another roll of labels.
If the printer is printing blanks in between labels, it probably needs to be gap sensed. You can do this by:
1. turn the printer off.
2. hold the feed button down and then power the printer back on while still holding the feed button down.
3. release the feed button when the light flashes.
4. the printer will then regap itself
5. when the regapping is done, press the feed button once. It will print on the label that it is 'out of dump'
6. the printer should then be ready to go.
May 03, 2008 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Thermal Printer Logo
6,510 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
