It could be that the compression rings went bad and getting what is called blow by, or the valve guide seal. if you can get your hand on a compression tester check the compression. you can check the compression by removing the spark plug and inserting the tester I don't know exactly what the psi is but should be at least 100 plus and within 20% of each cylinder. If you find that the compression is low, with a oil can squirt some oil into the spark plug hole that is bad. If the compression rises then it's probably the piston ring if not the valve seal is probably bad. 2006 shouldn't have that problem kinda new. get back to me
it has some kind of pipe that runs from the head to the airbox via a pump attached to the carb.
when i opened the airbox there was lots of oil residue in there... and now it smokes a lot when its running.
it's probably a smog pump of some kind, yes they put them on motorcycles now !!!!!!!!!! darn. still check the compression because the oil should not be blowing into your air box. is the pipe connected to the exhaust?
